When to replace a refrigerator
Originally Posted By: dishdude
White appliances are outdated. They're perfectly fine for a garage, basement or apartment but not for a modern kitchen.
I just realized: the fridge that came with my house is beige. I bought the house long before I wound up... driving Toyota's.
Is it my fridge's fault that I've turned into a soulless appliance driver???
Originally Posted By: aquariuscsm
What I wouldn't go anywhere near,are those with all the touchscreen and plastic bling trash all over them. I'd go to a restaurant supply house and get the most basic built like a tank fridge I could get my hands on. I detest bells and whistles on anything.
While I mostly agree... Few years ago our washer up and quit. No readout on it, so all it could do was beep at us. Took us several days to realize that the magnet we had strangely found near the washer belonged to the soap tray--we had picked it up, thought it odd, and (thankfully) stuck on the fridge. Low and behold, on a lark I looked up and at the tray, and there was a spot for that strange little magnet. Snapped back in place, and that's been the only hiccup in the last 10 years.
A readout as to "soap tray error" would have been helpful!
Now our microwave is older, probably 15 years or so old. Does have a simple digital readout. When we bought the house it gave no indication of problems--but didn't make any heat either. [I missed it on the home inspection.] Got it fixed on my dime (output tube and diode). Fast forward a couple of years and it quits again. This time the display popped an error code. Quick websearch indicated main relay failure so I opened it up. Relay was obsolete but I found a similar unit and jumpered it in, and it's been fine since.
Simple readout of a simple error, and it was simple repair. What a concept.
I've whined for years that all cars ought to be required to scroll out whatever OBD trouble codes it has without needing a code scanner. If my microwave could do that--why not my $20k automobile? [Yes I know a number of the trucks now do that, but it wasn't that common until a few years ago.]
Originally Posted By: Turk
I have a RUNNING Frig in the garage from 1956.
1956!!
It won't stop running!!
You better go catch it before it gets away!
Nonsense, they are timeless. Plenty of folks with basic white kitchens around they are still placing them in spec homes today, and that white fridge looks perfect there. The nice thing is that when white fridges become "trendy" once again you'll still have that classic one in YOUR home.
We have not put a white kitchen in a spec home in 15 years.
White is trendy again, but not the white your probably thinking of. Unless since your in Stamford your talking about $1m+ spec homes, or trendy rentals being built down town.
37299
This is what is trending in 2015. You probably see them down in your area.
Low end white and black appliances are still out unless your furnishing an inexpensive house in Bridgeport.
1956!!
I love those green appliances!! I actually love that entire kitchen! Only thing I'd change would be to put some stone tile down.
"Harvest Gold" was the yellow color I believe. I don't recall the name of the awesome baby poop green. LOL.
You can keep posting that video as my trendy appliances continue to operate silently and efficiently. Don't you need to go refill your ice cube trays and defrost the Norge?
We did a kitchen remake 12 years ago. ..Granite tops, Paykel Dishwasher, cabnet refinish, tile backsplashes, new flooring. Guess what, our Whirlpool range, and Side by side fridge look great. Fridge uses 2 KW/day. Extremely efficient....oh yea its 18 years old.
Thanks for helping the economy...we appreciate it.
Hey everyone so my wife bought some half and half a few days ago and within two days it was spoiled. Thinking maybe it was just a bum carton of half and half didn't think much of it then I went to grab a water out of the fridge it was on the door and it was cool but not really cold. So I decided to put a thermometer in the refrigerator and it is reading about 42 in the center shelf of the fridge . The thermostat setting is set one notch colder than the recommended setting. Could it be getting weak is it common to fail in that fashion?
The door seal appears fine I did check for dusty coils I usually clean them every 3 months or so though so it was fine.
The compressor was very warm to the touch so warm you comfortably hold your hand on the compressor
Compressors are usually warm to the touch. Half and half doesn't go bad quick, it sits out at room temperature all day in diners and coffee shops and doesn't go bad.
Well that went bad a little half gallon of milk now and we just bought the milk 3 days ago .
turn down the fridge to the coldest setting and see what the temperature is. if it's the same temperature of 42 degrees, could be a seal leak
While not likely it is possible that the store you bought the dairy products from had a shipment that sat out too long before being stocked.
Hey everyone I did turn the fridge down all the way and when I woke up that morning it was at 45 so not wanting to risk it any further I went out and bought a new one. We leave for vacation in a few days and I'd hate to come home to a bunch of spoiled food.
Well it sounds like it's time for a new one. It's quite the coincidence that this thread started as some broken trim pieces a few days ago and now all of a sudden won't cool.
