...I know the first response will be to call Frigidaire. I did that. Already went through the warranty process. Frigidaire/Electrolux elected to give me a complete refund and told me to keep the refrigerator. Now I'm just trying to figure out if it's a design flaw or something that I can reasonably fix myself? It's a long sorted story I'm willing to discus but for now, just the specifics...
Make: Frigidaire
Model: FRSG2115AV
Purchase date: 1/1/2025
Purchased from: The Home Depot
Issue: When the refrigerator is set at the lowest set-point of 35 degrees (F), it consistently measures above 40 degrees (F), typically within the range of 42-44 degrees. This even when left overnight. The concern here is proper food preservation with meat and dairy products. For example, the FDA states proper food preservation is 40 degrees (F) or less. The Frigidaire website states that a side-by-side refrigerator should be set to 37 degrees (F). In either case, the refrigerator rarely if ever sees these temperatures. And when opening the doors during meal prep, it takes what seems like a long time to pull the temps back down to the 44 range. For a new refrigerator, this doesn't sit well with me. I'll post three(3) picture(s) below of what I'm seeing...
Below: temperatures taken with my Type-K Thermocouple Thermometer with an advertised accuracy of 2.2 degrees or 0.75%. T1 = Top shelf. T2 = Bottom shelf. Both are running at around 44 degrees (F). Probes have been in the refrigerator for a couple hours.
Below: T1. Here you can see the Type-K digital thermometer in relation to the mechanical Pecula gauge. The picture above shows 44 Degrees (F) at the same time the Pecula mechanical shows around 38 Degrees (F). Also note the little red plastic cup placed at the back of the shelf, it's completely iced over. Some say these temps are within the realm of "normal" operation but all other reference refrigerators I've owned or still own cool better than this. If this was your "new" refrigerator, what would you do with it. Side note: We do have a colder secondary refrigerator that we are keeping meat and dairy in. Our saving grace but not the most convenient.
Make: Frigidaire
Model: FRSG2115AV
