Originally Posted By: virginoil
Originally Posted By: ron917
My '07 Outback 2.5i just turned over 70,000 miles. It is seeping oil from the the head gaskets (no drips yet, just wet). This is a very common problem with Subarus, obviously a design defect.
After reading that many folks were still seeing HG leaks despite statements that Subaru solved the problem in 2003, I switched to Mobil 1 High Mileage 5w30 at 62K miles. The next OCI at 68K miles was also Mobil 1 High Mileage 5w30. It started seeping sometime in the last 2K miles.
So in my case, the High Mileage oil didn't help. Or maybe it DID help, and the leak would have been worse if I did not switch to High Mileage oil.
The real fix is multi-layer steel head gaskets, available aftermarket. Subaru should have used MLS at the factory.
What oil were you using before the switch to Mobil 1 High Mileage and what OCI were you doing.
You may have just clogged up the filter if you didn't follow the correct switch process when changing oil brands etc.
Have a read of the link below:
http://www.pecuniary.com/faq/high-mileage.html
The filter is not clogged, my engine is clean. The vehicle has been running M1 or Pennzoil Platinum 5w30 since 5K miles, with 5K to 6K mile OCIs. Before that, quality conventional oil (Castrol GTX or Mobil Clean) at 1K and 2.5K miles. Always with a genuine Subaru filter (OCOD painted blue
