Not too long ago, in a VR&P thread, someone asked if VR&P would do any good on a '60's - '70's oil burning engine. The answer was given by someone, I forget who, who said that modern engines tend to burn oil because the rings are stuck, and older cars burned oil because the rings or bore was worn. Therefore VR&P isn't going to do anything for a '70's engine, for instance. I'm deliberately leaving out things like valve seals/guides etc., because I'd like to know if this is true.
I'm somewhat aware of modern ring and cylinder coatings. Do these prevent wear to the cylinder bore and piston rings? I haven't taken apart any modern engines, just an old 300 Ford, and a Datsun 2.0L. Also, can you rebuild these engines that have the specialized coatings? I know you can get coated piston rings, but what would you do to the cylinder bores?
