Was wondering about this today. Growing up I recall diesel rated straight 30 weights and 15w40
I can’t find any answer to when 15w40 oil came out. Google is worthlessI believe that 10w30 predated 15w40, which was a wildcat grade achieved by mixing SAE 50 with 10w30.
I recall my real dad telling me when he ran a R Model day cab MACK circa 1981 they plugged the rigs in but they sat outside all time. Never a issue with 15w40 on starting.interesting question @53' Stude
IMO, I think it is MPG related for the most part. I stick with the good ole 15w40 but have considered 10w40 for easier winter starting... My UOA's showed 5w40 was prone to shearing in my truck.
Just my $0.02
When was the SAE J300 viscosity table established?I remember when Pennzoil put out some really odd viscosity oil. I believe they even made a 15W-20 flavor.
ebay
Very Interesting! Point #2 is why I saw 10w-30's having more additive package "Totals" than a 15w-40 when I put together "Diesel VOA Database".
Thanks for your info user friendly
Also probably not of value to the OP: I know that up until about 1996* , most off the shelf multi-viscosity oils were dual rated for both gasoline (S) and diesel (C). I used to buy regular 10W30 oil of any brand for my small workplace Kubota tractor because it had the "C" rating. In 1997 I became alarmed when my new case of NAPA 10W30 had printed on it "For gasoline engines only". Whaaaaat???? I was not educated about HDEO oils at the time, but remember switching to 15w40 because I could not find 10W30 "C" rated oils anymore - note that I was not BITOG OCD at that time, and just followed the tractor dealer's advice to use 15w40 HDEO "C" rated.Was wondering about this today. Growing up I recall diesel rated straight 30 weights and 15w40
I was told back in the day that "C" was for compression ignition and "S" for spark ignition.Also probably not of value to the OP: I know that up until about 1996* , most off the shelf multi-viscosity oils were dual rated for both gasoline (S) and diesel (C). I used to buy regular 10W30 oil of any brand for my small workplace Kubota tractor because it had the "C" rating. In 1997 I became alarmed when my new case of NAPA 10W30 had printed on it "For gasoline engines only". Whaaaaat???? I was not educated about HDEO oils at the time, but remember switching to 15w40 because I could not find 10W30 "C" rated oils anymore - note that I was not BITOG OCD at that time, and just followed the tractor dealer's advice to use 15w40 HDEO "C" rated.
* 1996 +/- is when the feds changed engine oil classifications for gas/diesel. This started my interest in lubrication for fear of ruining my diesel tractor engines. I remember calling NAPA/Valvolene to get the answer about "C" being dropped off regular oils.
When were SAE 15, 15W, 25 & 25W grades added?
