I just brought home my new (to me) 2006 Pontiac Grand Prix GT and discovered a defect I was previously unaware of because I did not get it up to highway speed during my test drive (yeah, my bad): when driving on the freeway at 55 mph or above, I can hear a whining sound up front and the steering wheel begins vibrating. AZ's troubleshooting guide says that it is a worn, dry or damaged rear wheel bearing. A mechanic replaced the front passenger-side wheel bearing/hub assembly yesterday in order to fix an ABS/TC issue and he let me feel the worn hub assembly he removed, which I could feel "grind" as I turned it in my hands. Should I assume the driver side hub assembly is bad as well and go ahead and replace it myself?
Each Duralast hub is $90 (1 year warranty), I can go with US-made Timkens for $145 each (3 year warranty), or Precision (3 year warranty; unknown country of origin, but made in ISO9001 or higher certified factories) for $143. The mechanic used a Duralast, but I'm sure he was just going with the cheapest option.
