Originally Posted By: Tempest
Originally Posted By: Kestas
The only thing I can imagine is that the original grease could not withstand the high temperatures developed during the race, and they went with a more temperture-resistant grease.
Higher use of brakes than OEM intended?
Both braking and cornering forces well in excess of 1.G, as well as the significant loads these forces place upon a chassis running slicks. Head generation from the brakes making it's way into the hubs. OEM brakes aren't going to see 1200*F+ temps repeatedly, lap after lap, like a racecar will.
It was kind of 'beaten' into me as a kid watching what my dad did and used. I know, conventional wisdom and not science, BUT - what he did worked, for his uses. For chassis grease - it was Kendall SuperBlue, and he had significantly fewer parts failures than people running other 'lesser' greases. And Chicago Rawhide seals, never saw one fail, while I saw National oil seals fail often. So, to this day, i run SKF 'green' CR seals ONLY. It's one of those situations where I KNOW they're a well built seal, regardless if the other will work or not. He sued FRAM filters exclusively though too, but you won't catch me dead using one of those...
