these aren't too bad but i think they are funny. one time i needed to spray the carb with some carb cleaner. i carefully lined up my finger with the exact spot that needed cleaning, eased the nozzle down with finger and promply shot myself in the eye with it. i wasn't paying attention to where the nozzle was pointing. it burned for about 10 minutes and i learned my lesson the hard way.
a better story is when i had my wife help me bleed the brakes on my pickup after having the whole system apart. she was the "pumper" i was the "bleeder". she had never done such a procedure and didn't really have any idea what we were doing so i explained the routine. she starts pumping away then holds, i get nothing out of the bleeder. pumps, holds, nothing, again, again, again, 30 mins later nothing, no pedal at all and no fluid from the bleeder. hmmmmmm lots of air in the system i thought. send her out to get a mighty vac vaccuum bleeder, that'll fix it! while she's gone i push on the brake pedal and it has a small amout of pump up, that's odd. think about the problem for a bit then relize the answer, improperly trained assistant! she doesn't know how to drive a manual transmission and was pushing on the clutch pedal!!! it was confirmed when she returned with the mighty vac.
