- Joined
- Jan 6, 2005
- Messages
- 10,342
For several years now on an intermittent basis, the Edge's climate control loses its mind. When this happens in the summer, hot air will blow from the driver's side vents and cold AC will blow from the passenger side vents. In the winter, IIRC the problem is cold air on driver's side and heat on passenger side. The short term fix for this is to turn the ignition on without starting, press climate button and defrost button at same time, release both buttons, and press climate button twice. This performs some sort of reset after which the climate control works correctly for an unspecified period of time until it happens again. It has happened more this year than in any previous year.
What does the BITOG crew think the problem is?
