My wife was complaining of little or no heat in her car.It is a 98 Olds LSS with the 3800 engine and auto climate control with dual zone heat and cooling. I took it for a ride and had it fully warmed up and noticed that the drivers side vents blow lukewarm heat and the passenger side blows cold air with the passenger side control turned all the way to warm.Would a malfunctioning thermostat cause this? I had it set on 90 degrees and the heat coming from the drivers vents was not hot.Any advice?
Thanks
Thanks
