My personal favorites are the Motorcraft synthetic blend, Pennzoil Gold & Valvoline MaxLife/DuraBlend
Motorcraft is 60% Group III synthetic & Ford has confidence in this oil out to 10,000 miles in some cases. I believe it's an excellent oil.
Pennzoil Gold is a 50/50 blend, I used to run it in a couple of my Ford's & it was always excellent. I followed the OLM to 7,500-10,000 on this oil. Typical Pennzoil quality!
Valvoline MaxLife & DuraBlend are 30-40% synthetic. MaxLife is obviously the high mileage version, but you'll have nothing but good results using it in an engine of any age or mileage. DuraBlend is difficult to find at reasonable cost in my area. MaxLife is basically DuraBlend + high mileage additives. I've had multiple good experiences with MaxLife & had a couple runs of DuraBlend in the '12 F-250 when it had 10,000-20,000 miles.
How do you knowvthese percentages, have a link to share?
Pennzoil Gold says 50/50 on the bottle. Valvoline employees online chat have told me MaxLife/DuraBlend are 30-40%. Ford dealer has told me Motorcraft is 60% & I have seen multiple people online state the same. No links needed. Look at a Pennz. Gold bottle, ask Valvoline on chat. As for Motorcraft, I suppose I can't technically prove it's 60% but I have heard that at least 10 times from different sources.
If thats accurate, good. But a semi can be anything having 10% of group 3 on it, witch does not do nothing, maybe make a group 2 getting SN Api, depending on its add pack. So, I rather brew my own lubes, also, from the information fluidity we got from such companies. Even though you dont have any kind of doc to instruct your 60% synthetic whatas bases arguments?
"If" the information is correct in the case of Pennzoil, then mixing your own Pennzoil Conventional and Pennzoil Platinum you can easily make a blend as good or better than what you can buy from them. I wonder if it is really that simple?
