What's different betw these 2 products? (Small DAC
Thanks!
Now there's a THIRD one to add to the mix
http://www.amazon.com/Digital-Converter-...0888&sr=1-1
So what's the deal with this particular DAC? Is it supposed to be of some very high quality?
Wondering if my squeezebox would benefit from it. It has a Burr-Brown 24-bit DAC.
No clue - it says the DAC is a Cirrus, which does have a good reputation.
I am planning to use this with the new TV (no analog out, no headphone jack) I have coming, when I use Roku3, which also has no analog audio outs. (Only optical out), so I would use this and probably use the '3.5 mm line out to connect to my usual Yamaha 2.1 PC speakers system (has great sound). OR use that output as a HP out. (I hardly use HPs with TV though).
I guess I can use the RCA out and connect even to the main lvg rm amp, but mostly the 2.1 Yamaha system is enough.
