I will check the code tomorrow.As mentioned in your now closed duplicate thread, check for any throuble codes for more insight.
Sounds too loud and too fast for injector noise at idle.
Sounds more like lifters than it does fuel injectors. A flashng CEL usually means there was some cylinder mis-fires.I will check the code tomorrow.
Does it sound like valve lifters?
I just went out to get the codes and nothing came up. There was no codes at all, not even stored codes.Judging by your video, the sound is the loudest just over the area where the purge valve is located. I have replaced a few of those on Chevy 3.6l’s that sounded just like that. It’s unbelievable how loud they can rattle.
Anyway, going by the video, that’s where I would start. Cheers!
Yes, replace it ASAP.I placed a mechanics stethoscope right on the purge valve and sure enough that's it
Is this something that should be repaired immediately?
