- Joined
- Jun 9, 2021
- Messages
- 155
Hello all,
I'm diagnosing a very faint "groan" when my ZF 8P75H (Full hybrid) is near the top of second gear, and immediately goes away as it switches to third. This is accompanied by an occasional rough switch to second gear, which I've been told is normal for these transmissions. The "groan" only seems to occur when I'm driving in electric mode - or perhaps I just can't hear it when the engine is running.
The car has ~75k miles on it. I did the first spill and fill as soon as I noticed the noise a couple of months ago by draining a gallon and putting a gallon back in, then rechecking the level (at the proper fluid temperature of 40C) after going for a long drive to open the thermostatic valve. Level was bang on, so that wasn't a problem.
I've now done two drain and fills and, although the gear shifts seem a bit smoother, the noise is exactly the same. It should be noted that I have not dropped the pan to change the filter. Has anyone experienced this in a transmission before? Any suggestions as to what this noise could be, and whether or not I should be seriously concerned?
Edit: I should also note that I do not experience any slip or other unusual shifting characteristics in any of the gears, aside from that occasional jerky 1-2 upshift. Although it's difficult to discern whether any of the gears are slipping in electric mode, I have not noticed anything that raises my eyebrows when watching the tach during gearshifts with the engine running.
