On both of my front rotors, there is a build-up of material on the inside only of each rotor (both sides facing the engine). The material is quite bumpy and I have no idea what it might be. There is a thin band of shiny metal showing from the small contact patch where the inner brake pads are still touching.
The outside faces of both rotors are completely fine, still shiny and smooth.
Both inner and outer pads look good so I'm at a loss to understand what might be happening. I checked the caliper and both inner and outer pads are sliding freely. The brakes still work fine and there is no vibration or anything when braking.
The truck is a 2008 Nissan frontier with a 6spd manual. I'm super easy on the brakes as I have 60,000 miles on the pads and they still have 75% life left. I'd be surprised if I've made more than 3 or 4 panic stops in those 60,000 miles.
Obviously I need to replace the rotors and pads, but I'm wondering if this issue might be resolved by switching to a slotted rotor? (I'm guessing maybe I'm too easy on the brakes and snow/ice/salt/road debris is getting trapped against the rotor? Maybe the slots will help displace the debris? I have no clue lol!)
Any thoughts/tips/suggestions on what might be going on?
