2004 Civic Brake pad shim question
Earth
Hi, I just replaced my front brake rotors and pads on my 04 civic LX sedan with genuine OEM Honda parts. The brake pads came with a shim for the outer pad and two shims for the inner pad (piston side). For each side.
The outer pad shim is black and I figured that out ok by the parts schematic on the dealer website. The inner pad however, was kind of difficult to make out based on the picture.
The inner pad's shims were 1 black and 1 shiny silver which was a thicker gauge metal than the black one. They are both used on the inner pad acording to the picture on the Honda dealers website.
I ended up putting the black one against the pad and the silver one on the outside so the piston will be contacting it. Both shims fit together fine via tabs that grab the edges of the brake pads.
Does anybody have first hand experience with front civic brakes using oem Honda parts that can let me know if this is ok? The test drive was fine and all seems well.
I put the silver on the outside because it would seem logical that the piston might be hard on the thinner black one and Honda uses the silver one as a "go between".
I cant compare setup to the old because it had aftermarket pads on there that dont use the same shim setup as oem honda pads. Thanks in advance.
I know that quite a few Hondas use two shims on the inner pad, with one being smaller than the other. The smaller one is suppose to be on the outside.
The most important part is that you have the correct number of shims on the appropriate side. Also, the molykote77 MUST be used on both sides of each shim for the noise reduction system to work as designed.
Thanks for the reply. The silver one is the smaller one, and it is on the outside (it contacts the piston). So It sounds like I have the shim orientation correct then.
The new pads came with a packet of grey antisieze looking lubricant. I used some on the metal clips that the pads slide into, and I also put some on the piston edge that contacts the inner pad. I didn't put any on the shims themselves because they already have that black coating on them. I hope they dont end up squealing on me
