Whatever Happened to 20W-20 Motor Oil
I remember that many years ago a grade of 20W-20 was marketed by Quaker State, and probably some others as well. I even remember a 10W-20W-30 that QS sold, but for now, let's stick to the 20W-20.
I suppose I don't quite get it. It seems that it was a multi-viscosity single-grade oil. Can someone explain it, maybe offer some background or history, and why it disappeared as a motor oil? It crossed my mind around Grinnell Iowa, as I looked at The Critic's 10W-20 that I'm bringing to him from HPL.
Lubriplate makes a non-detergent 20W-20 ... what's that used for?
UTF has taken the place of that stuff in the few real world applications still asking for 20w20.
https://www.yoderoil.com/wp-content/uploads/2015/08/KENDALL-NON-DETERGENT-MOTOR-OIL-PDS.pdf
Back in prehistoric times in better oils you had a winter rating and a summer rating otherwise it was mono grade which had no real winter rating.
We are talking the difference between SA and the later SB/SC oils
Which is basically pour point depresents which lowers the pour point.
https://bobistheoilguy.com/forums/threads/pennzoil-20w20.338594/page-2#post-6143734
monograde with acceptable winter performance. superseded by 10w30, 10w40, 15w40 and 20w50 in most applications
you can make a 0w20 with pretty much 0 VII (i.e monograde) if that clears it up
About 25 years ago the local car quest had some Valvoline 20w-20 on the shelf. The bottles were plastic but turning yellow. I saw them on clearance so i bought it and ran it in my 89 jeep I had.
You can still buy 20W-20 ... not many sources, but it's out there.
https://www.mystiklubes.com/Product.do?code=663112002&category=AGRICULTURE
"Mystik Non-Detergent General Purpose Oil is designed for use in non-critical applications where a general purpose oil is desired. This includes low-pressure hydraulic systems such as hydraulic jacks and air compressors requiring a non-detergent type lubricant. This oil is not recommended for use in gasoline or diesel engines."
Yep Hydraulic oil, an application where you could contaminate or mess up equipment if you use real oil
You can make a 5W-20 or a 10W-20 with no VII's using PAO, can probably even do a 10W-20 with GTL (just a guess there). So, it's essentially an obsolete grade at this juncture unless you wanted to use some real cheap basestocks up.
Perhaps a dumb question but what is the purpose of a 20W-20 versus a SAE20 grade oil?
Sounds like splitting hairs?
Well, not really, as I said you could make an SAE20 using Group I and it might have absolutely awful Winter performance like @ZeeOSix noted, making it a 30W-20 for example (or worse). Anything that's a monograde doesn't have to call out a Winter rating. Some companies DO provide it, like some of the aforementioned examples. If it has VII in it, it's required to show both the regular 100C grade and the Winter rating.
Okay. I was under the assumption that a straight 20 grade still had to fall within the range specified for it.
Nope. If we look at J300:
You can see that for the SAE 20 designation, there's no CCS or MRV requirements, just a KV100 and HTHS. You have to add Winter rating testing if you want to advertise a Winter rating, but that's not required with a monograde, it's only for oils that contain VII.
