I don't know, but if you are trying to age the oil, check for a date code and call Chevron to get the interpretation. Then you will know exactly how old it is. Otherwise, if you are trying to bracket the age, you also need to know when SL came out for the oldest it could be. Bottom line though is that you should be fine to run this oil, but I would shake it well in case there was some settling during storage.
