I agree that the exact amount specified by the owner's manual is usually not what you need to add to get it perfect. That's why I always add less than that number, usually by a quart or so, and do my pressure check. After the filter is filled and the oil drains back to the sump, I check the level and adjust after having it sit for 5 minutes. You won't do any damage by being a quart under filled at idle. There's usually a quart or two at most that circulate in the engine at any given time, and the rest is in the sump covering the oil pickup. Fill a quart shy of the target quantity and check. It's a lot easier to add oil than to take it back out. I wouldn't risk aeration by overfilling. I'd rather go with a bigger filter, or put the fraction of the quart left over into the back seat or trunk as emergency top off oil.
