My plan for my 6 speed in my Ford PSD is Amsoil ATF and a Magnefine filter.
I don't know how it is in truck or GMs, but in my GT, D mode skips multiple gears and acts like a 5-6 speed. In S(port), it goes through all gears...and much more fun!I would say that these new 8-9-10 speed transmissions are MORE likely to load up a filter since they're doing a whole lot more shifting, so the clutches are cycling a lot more often. Stock-for-stock, they're also being asked to deal with more torque on a regular basis and do it with fewer friction surfaces.
At least in the trucks, Tow/Haul makes them not skip at all. All 10 up, all 10 down.I don't know how it is in truck or GMs, but in my GT, D mode skips multiple gears and acts like a 5-6 speed. In S(port), it goes through all gears...and much more fun!
Before I bought the car, it had a solenoid go out at around 10k so it had a fluid change. Last year, I took it in because of initial jerks when going into R and then what seems to be a too long of o pause when going into D. Had the valve body replaced (another fluid change) and was told to drive for a while to let it learn. Still doing it. Will take it back soon.
On the mustang6g forum, a tuner, Wengerd, seems to do magical things and TRANSforms (pun intended) with no issues.
Is this transmission made by Ford or is it made by ZF?
Got it. Thanks!A joint venture between GM & Ford.....Ford doing the bulk of the engineering.
Could you explain why, exactly?2. Always change filters, regardless who says not to
I have the same tranny on my ‘22 Sierra. The filter is rather large. The dealer and transmission shops recommend service at 45K intervals for Severe Service and nothing for Normal Service. I had the dealer do a flush the first go-round at 50K. Price, $425. The next two intervals, I did a pan siphon and refill at 75K and 100K. Price, $22 (4 qts ULV from Rock Auto + tax and shipping). I used to run a two factories that made transmissions, so know how to do it. Note that the fluid goes dark quickly on these transmissions. Dealer wants $675 for full service filter and fluid change.On the 24 Tahoe with the 10L80 transmission. I’m trying to plan ahead and form a service interval plan.
I am only at 10k miles. I know I’m very early on, but I love this truck and want to keep it for a long time.
I guess I’m trying to decide:
1. What should the first service be at?
2. Should the filter be changed at this first interval? Fluid only?
3. Should subsequent services be the same mileage intervals?
4. Filter every time, or only every so often?
If no to a filter every time, perhaps I should change to a pan with a drain or maybe I’ll have my welder FIL weld a drain bung to the pan.
Wonder if an aftermarket pan or a drain added to the OE pan would make GM void a warranty in the event of blowing up a trans.
I come from the world of servicing a 4L60E every 20k with drain and fills and every so often a filter… with long healthy trans life. For example I don’t like letting fluid get nasty. I feel you keep the fluid clean they’ll stay healthy.
Not familiar with the 6R80, but the '10X' filters are big, and nice, but still don't filter as well as they need to in order to keep valve body wear and sticking down.
I know the pitchforks are going to come out when I post this (Because everyone seems to hate YouTube), but there is a LOT of good information in this talking video from someone in the aftermarket that seems to be putting some effort in to solving some of the '10X' problems. A lot of it lines up with things I've learned from other sources. Yes, his flat bill hat is rediculous, but the information is sound. Speed it up to 1.75-2x as it is a bit slow.
I have bookmarked a few interesting areas of his 'talk'
Mainly. It doesn't take much to knock these things for a loop, keep your fluid clean.
Links below are at specific sections of the video:
Talking about solenoids.
Talking about Ford/GM 10R80/10L90 and more sticky valves
10 Speed Shift oddities (hint, it's a slow valve body)
Small particles in the valve body.
It was recommended by GM on all their Hydramatic transmissions. Why fill anything will fresh oil and a used filter. Unless it is the non service transmissions and in that case you can't.Could you explain why, exactly?
How did you like the PPE Pan? It looks like a pretty nice piece.Yep, sooner rather than later for sure.
I dropped my pan to do the PPE pan. Nice having the drain plug, but an expensive option for sure.
That and someone on the Ranger board developed a bespoke dipstick for us. My changes take less time than changing the engine oil.
