What should I service this 10L80 at?
Just trading emails with a service rep (huge dealership) asking cost of ATF and filter change (Tahoe 10 speed). He said we don’t do that - the way we conduct the flush cleans the filter.
this is so wrong and outright lazy. it isn’t hard to pull the exhaust down to do it right.
No experience here but it sounds like an inline filter would be a good idea on these
Not really. The factory filters are an extremely nice filter. They're far different from the old 'rock catcher' filters on old automatic transmissions. There's just nothing out there that will catch and trap the contaminants that are causing the valvebody wear.
I have a post somewhere on here of a 10R80 filter C&P, can't find it at the moment of course.
inline filter is a great idea. often cooler lines catch a slip stream or full flow off the torque converter/rest of the transmission before it gets discharged into the pan so catching it before it makes it to the pan filter is beneficial. i have inline filters in all of my vehicles (XG8a sized filters)
inline filter is a great idea. often cooler lines catch a slip stream or full flow off the torque converter/rest of the transmissionmission before it gets discharged into the pan so catching it before it makes it to the pan filter is beneficial. i have inline filters in all of my vehicles (XG8a sized filters)
Love me some inline transmission filters. I’ve used both magnefine or remote-plumbed a spin-on. Both did good. Given the space I’ll do a spin-on, which can also support a temp sensor for a real gauge.
The aluminum these units shed is off the charts & It's so fine I don't think any filter media will trap it without causing a restriction.
Here's 10L80 separator plate, You can see all the aluminum debris, One of the screens got so loaded up it blew out.
I replaced the OEM plastic transmission pan that STUPIDLY, and to pinch pennies I assume by Ford and GM does NOT have a drain plug!!
I went with The non deep PPE pan on my 2022 Mach. No complaints after a month or so of driving.
I like that it is aluminum and that it has cooling fins and a magnetic drain plug.
Like many of people have sit on here about the transmission, eating itself. Due to aluminum working against a much harder steel, and therefore the aluminum filling the transmission with aluminum shavings, doing a draining fill of transmission fluidwith every engine oil change would probably be a good idea.
Ford replaced my 10R80 transmission after just under 10,000 miles on the car. Of course, after fighting with them and going to multiple dealerships and different states.
On the 24 Tahoe with the 10L80 tranmissionmission. I’m trying to plan ahead and form a service interval plan.
I am only at 10k miles. I know I’m very early on, but I love this truck and want to keep it for a long time.
I guess I’m trying to decide:
1. What should the first service be at?
2. Should the filter be changed at this first interval? Fluid only?
3. Should subsequent services be the same mileage intervals?
4. Filter every time, or only every so often?
If no to a filter every time, perhaps I should change to a pan with a drain or maybe I’ll have my welder FIL weld a drain bung to the pan.
Wonder if an aftermarket pan or a drain added to the OE pan would make GM void a warranty in the event of blowing up a tranmission.
I come from the world of servicing a 4L60E every 20k with drain and fills and every so often a filter… with long healthy tranmission life. For example I don’t like letting fluid get nasty. I feel you keep the fluid clean they’ll stay healthy.
I did 50k pan drops on my 2020 3500 and sold the truck at 194k miles with no tranmission issues.
On the 24 Tahoe with the 10L80 transmission. I’m trying to plan ahead and form a service interval plan.
Wonder if an aftermarket pan or a drain added to the OE pan would make GM void a warranty in the event of blowing up a trans.
I come from the world of servicing a 4L60E every 20k with drain and fills and every so often a filter… with long healthy trans life. For example I don’t like letting fluid get nasty. I feel you keep the fluid clean they’ll stay healthy.
Thanks for this post, you saved me from writing a similar one. I'm in a 2022 Yukon XL and have 50k on it right now. Looking at doing either the flush (dealer recommended) or the pan drop and filter change. Looks like I'll pony up the extra $$$ for the pan drop.
How much fluid is not changed with the pan drop only vs the flush?
I'd also add that I am not loving the idea of the flush, although I read that the new flushing systems are more gentle than the older ones that were known to cause problems.
Think about adding an upgraded oil pan with a drain plug. I bought the PPE for my 2022 MACH one it’s aluminum and has a magnetic drain plug. I have been doing a draining fill every 5000 miles. But I also do HPDE with mine so I am probably a lot harder on mine than you are. I could probably go a little longer before I do a draining fill. if I were to guess I would say you should probably change or just do a drain and fill yours at least every 30,000 miles or less. the 10R80 transmission is notorious for eating itself so getting out all of those shavings would probably be a great idea.
Do you fill through the check port, and how do you know how much to add? I hear that refilling is not straight forward on these transmissions.
