Hi,
First time posting here and I need some advise.
What is the best oil for my car and climate?
I know there is no best oil.
Here are all my specifications:
1989 Toyota Corolla 4A-F engine 260,000 miles
Owners manual says API SF/CC or SG
SAE from 5W-30 to 20W-50
OCI recommended 5000 miles under severe conditions
I drive a mixture of city and highway
I work from home so I don't commute
I have been using Chevron Supreme 20W-50 because I thought I needed a thicker oil for an over the hill car.
My eyes have been opened.
The car used to leak oil every 3000 miles or so due to bad gaskets and seals. When my mechanic replaced the timing belt he replaced all the necessary gaskets and 2 oil seals, now it doesn't leak at all or at least as much.(Has only been 1 month)
I live in Western Washington. Tacoma actually
I would like the opinions of the this forums memebers as to which oil I should be using in this car. Oh,It is my daily driver and only car. Maintainance is very important to me.
I have been buy the Chevron Supreme 20W-50 conventional oil at Costco with a coupon for about $15.00 a case.
I prefer over the counter oils rather than online.
I don't care if it's conventional, synthetic, or a blend.
Just want the best for my situation.
I have used Walmart's Super Tech in past,but that was before becoming Costco member.
That is all the info I can think at the moment , will answer questions when they come up.
Thanks in advance,
Jabe
Thanks in advance,
Jabe
