Originally Posted By: BuickGN
I would think that a higher spinning, high hp motor would be a little more tolerant to thin oil than high torque low rpm motor. The Buick which made it's 600+lbs right around 3,000rpm has shown it hates thin oils. My theory is the only reason I didn't put something thicker in my torquelss wonder TL for the 110+ degree summers in Vegas and Phoenix.
But it's oft RPM that kills a stock V8.... The rev limiter on these puppies was 6,250, and they didn't make power past 5,000RPM stock. So the stock bottom-end being spun to 8K on 0w20... And it holding up????? That was the surprise.
What kind of clearances are you running in the bottom-end of your GN? I know that an engine can be built for a specific oil thickness in mind... Loose engines require a heavier oil. I imagine with the power numbers you are making, and the use of the car, it was probably built on the loose side? Thus it probably wouldn't fare well on thin oil.... Which seems to echo your experience.
Not really loose. .0015 on the rods, .0018 on the mains, .004 piston to cylinder for the JEs. With the exception of the pistons, all stock cast 2-bolt bottom which seems to move around a bit under lots of power. I'm also spinning mine about 1,000rpm over the stock 5,250 limiter. I honestly can't remember the stock specs to compare it to. I do know, however, that oil pressure is nearly double the stock spec with only a stock clearanced pump. I don't like that going down the freeway I'm near the 70psi relief but when I've run a lighter weight, I've had much more wear on the teardowns but no outright failures.
That is impressive though, a stock bottom 5.0 spinning that kind of rpm reliably. I had no idea it was a stock bottom car.
