Just see what everyone with a VW is using for oil out there? I’ve got a 1.8 TSI and it needs to meet the VW 502 00 / 505 00 requirement. Do they like 5w30 vs 5w40 better?
Which also renders the grade irrelevant. An engine isn’t going to “like” a 30 or a 40-grade with the approval any more or less than the other.VW 502 approved oils in any viscosity have a minimum HTHS of 3.5. So a VW 502 5W30 is thicker than a the typical 5W30 specified for American and Asian brands.
“Like” the approval more than the grade.Just see what everyone with a VW is using for oil out there? I’ve got a 1.8 TSI and it needs to meet the VW 502 00 / 505 00 requirement. Do they like 5w30 vs 5w40 better?
Why. Just why.Any Volvo vds 4.5 or ll 01 40 grade oil and anything Full Synthetic below 40 grade.
I'd take the cash back on the Valvoline since both will meet your VW 502.00/505.00The easiest obtained is the euro spec Castrol 5w30 and the euro Valvoline 5w40 for me. Not sure which to use. Says Castrol on the oil fill cap but that’s paid for by Castrol
A 5W-40 with the same spec still has higher HTHS than a 5w30 in the same spec. I think that's more along the lines the OP is asking.Which also renders the grade irrelevant. An engine isn’t going to “like” a 30 or a 40-grade with the approval any more or less than the other.
Maybe, right? But not necessarily, the KV can be the same but the HT/HS can be different. Somewhat dependent on the amount and type of VII. At least that’s what I thought.A 5W-40 with the same spec still has higher HTHS than a 5w30 in the same spec. I think that's more along the lines the OP is asking.
The manual says it came with 5w40. Or 5w30 lol very confusing. Which would be better for all year use? I live in lower New England1.8 TSI here and have run a variety of the 502 oils. Liquimoly products, M1, Quaker State, now High Performance Lubricants. Honestly in a normal daily driver application any of what you get at Walmart or the auto parts stores that is a Euro xW40 502 oil - Castrol, M1, Valvoline. If you want to order the LM kits online from the popular Euro parts vendors also easy but will cost a bit more than the ones I mentioned above unless you get into the FCP lifetime replacement deal then it will be free after the first change with some work. 30 vs. 40 is really just up to your preference just like 0 vs. 5 winter rating - they all have the same 502 approval. Remember 504 is reverse compatible so that opens up some other xW30 options.
Again...don't worry about viscosity. Approval. 502 is 502 and all compatible regardless of the 0 vs. 5W or the 30 vs. 40. It's not cold enough where you are to have issues with either. I'd say run a 0W40 that has the 502 approval like Mobil 1 0W40 or Castrol 0W40.The manual says it came with 5w40. Or 5w30 lol very confusing. Which would be better for all year use? I live in lower New England
Why 0 and not 5?Again...don't worry about viscosity. Approval. 502 is 502 and all compatible regardless of the 0 vs. 5W or the 30 vs. 40. It's not cold enough where you are to have issues with either. I'd say run a 0W40 that has the 502 approval like Mobil 1 0W40 or Castrol 0W40.
B/c Mobil 1 0W40 is a v. popular high-quality oil...no other reason. It's likely not cold enough where you are to need the 0W...the 0 and 5 will essentially be "the same" or "interchangeable". So if your manual says 5W40 clearly that's what you seem to be gravitating towards....so many versions of it just get a 5W40 then. They all work in your car b/c they all have the same approval. I've used both but the 5W40s almost the whole time (1 change with Mobil 1 0W40 on this car....used it almost exclusively on my '00 Jetta that went 220K/14 years with me on 10K mile oil changes). You won't be able to tell the difference and neither will your car..hahahaWhy 0 and not 5?
To clarify, in the same brand. Of course there can be KV100 and HTHS differences between brands when comparing the same viscosity rating. But in the same brand and with the same VW spec, I'd bet a 5W-40 will have a higher KV100 and HTHS than a 5w30.Maybe, right? But not necessarily, the KV can be the same but the HT/HS can be different. Somewhat dependent on the amount and type of VII. At least that’s what I thought.
