Exactly. Just like Lubegard Complete Synthetic Power Steering Fluid that's literally compatible with every single car except Honda/Acura. It also specifically states it works with cars that call for CHF hydraulic fluid. So, exactly how different are all these power steering systems? Well, who knows, I bet it would even work fine in a Honda/Acura... a power steering system is a power steering system.
At the end of the day these transmissions are all functionally similar and the fluid performs the same basic functions in the transmission. I believe that Valvoline would stand behind their product if you could PROVE it caused the failure. Keep in mind that the majority of people are changing or adding ATF because something isn't right with the transmission, so "my 300k 4l60e died 100 miles after I put in Valvoline Maxlife ATF" well there's a large chance the transmission died not because of the fluid, but because it's worn out. I would say the folks on here that are simply servicing their ATF on a regular basis for proper maintenance reasons are the MINORITY and for those folks, well, if you go on the Valvoline website and look at the complete listing for the types of ATF it can replace, if your fluid spec is on there, you're fine to use it. Most people either never touch it or take it to the shop. Oh, and guess what fluid the shops buy from me? Valvoline Maxlife
