Originally Posted By: gomes512
Don't mean to divert this thread off topic but since we're on the topic of big diesels wanted to share some pictures I took when I was on a tour of the local university's power plants. Sorry not ship related but perhaps this will inspire someone to post some pics of big ship diesels.
Think this was a Wartsila unit biggest they had on campus running at about 100rpm. Not running when I was there, mainly used as a backup unit to turn that 8ft generator. Unfortunately, the tour guide didn't know many details about the engines themselves.
Here's the entire engine itself sitting behind the generator. Looked about 12 to 14ft high.
Got a chance to climb the yellow ladder flanking the unit. If I remember correctly it was 20 cylinders. Tour guide said it is normally started with diesel and then switched to natural gas.
The second unit was apart for repairs, check out the size of this head. I could easily fit my hand and arm through those valve springs.
As the tour guide was speaking I realized that the four foot high wooden box I was leaning on actually housed a cylinder from the unit under repair.
I asked about the lube they used for the engines, guide didn't know any specifics other than there were two separate lubes used, one for the crankcase and another that was fed to the cylinders with the natural gas. In the basement, below the engine, was the crankcase lubrication system. Think I spotted a 750 or so gallon tank of "engine oil".
Walked by a huge holding tank for dirty lube.
And your run of the mill 5ft oil filter... Wonder what the media looks like.
There were 5 other smaller Wartsila units, all standing by as backup gens. This "small" 18 cylinder unit was about the size of my Corolla.
Medium sized Wartsila, actually three sitting side by side. Guide told me that they are capable of burning up to 80 gallons of diesel an hour.
The four smallest diesels where Caterpillar units, mainly used as backup gens for the power plant itself. The guide explained that they reminded him of a B-17 starting up. Presumably there is a rather impressive smoke show until the exhaust manifold heats up and its full expansion allows for a proper seal.
This CAT actually had a few drums of Rotella T 15w40 sitting around next to it, but the guide was unsure if that oil was used for those units or not.
Was very impressive to see such big engines up close, can only imagine the size of the units some of the large container and tanker ships use.
Playing around in the medical district I see ;-)
Wartsilla engine there I believe is 5,000kW; it would be sucking down 350 gallons per hour at full name plate kVA load. I think the Wartsilla's backup the turbines, that are prime power.
The smaller units, CAT, Cummins, 2 detroits are all connected to medium voltage switchgear, backs up the critical loads.
