What is your OCI and brand of oil being used?
2001 Mitsu Eclipse Spyder (I-4)- Havoline 5W30 Synthetic - Wix filter - 3K interval (will probably bump up to 5K if UOA looks good)
2002 Mazda Protege ES - Havoline 5W30 Synthetic - Wix filter - 5K interval (this is the factory 'Severe Service' recommended interval)
2003 Mazda 6s, 0w-20 Mobil1 (year round) with a K&N 2010 filter. Drain interval is every 5,000 miles (due to autocrossing).
1974 Grand Am Pontiac, 10w-40 Mobil1 (thinking of switching to 15w-50 mobil1), with a K&N filter. Drain interval is by month...usually every 4-6 months. (Doesn't get much use now)
Here's my contribution:
2002 Nissan Maxima (VQ 3.5L)
Mobil 1 5w30
Purolator PureOne PL14610
4,000 miles OCI
2003 Honda Odyssey (3.2L)
Mobil 1 0w20 OR Motorcraft 5w20
Purolator PureOne PL14459
4,000 miles OCI
'01 Lightning - 3K after initial one at 2.5K
'03 Expedition - 3K winter, 4K warmer weather..
'93 Dakota - 4K
'67 Galaxie - once a year .. 0-2K miles..
1998 Taurus 24v (63k miles)
Frmly - Pennzoil 5W-30
Now - M1 5W-30 (Have some GC for next winter)
Motorcraft FL-820s filter
3,500 mi. OCI
2003 Explorer 4.6 Mod (8.7k miles)
So far M1 0W20 am leaning toward Motorcraft 5W-20 for next change (coming in just 300 miles!!!!)
Motorcraft FL-820s filter.
3,000 mi OCI
1990 Cadillac Coupe DeVille Odometer: 40,928
SuperTech 10W30 + SuperTech oil filter
1994 Chevrolet Corsica Odometer: 91,478
SuperTech 5W30 + SuperTech oil filter
1993 Ford Taurus Odometer: 116,675
All vehciles changed at the manufacturers recommended interval of 3 months/3,000 miles. The manual says to use an SL and GF-3 rated oil and change it at 3 months/3,000 miles, so that is what I do. No sense in using Mobil 1, AMSOIL, or any other synthetic oil, just use anything that meets the specifications. Oil brand means absolutly squat IMO. The engine is designed to use an SL rated oil so use anyone you want. If you use an oil that meets the specs, the right viscosity, and change it at the recommended interval, you will not gain a thing buy using $5.00/qt. Mobil 1. So if the manual says to use a 10W30 viscosity, SL and GF-3 rated oil, and to change it at 3000 miles, do it with whatever the heck you'd like.
IMO the best way to get 100,000's of miles out of your car is to read the manual and follow ALL of the maintenance proceedures to the tee.
ie: if the manual says to flush your coolant every two years or 30,000 miles, do it ATLEAST that often. Same goes for all other fluids and proceedures. If you do this you will see many many happy miles out of your vehicle.
BTW I think many of us on here spend to much time thinking only about the oil and filter aspect of a car and forget about other things like flushing transmission fluid, brake fluid, tune ups, ect... Yes oil is the most needed and changed item on your car, but everything else should not be forgoten. Ok I'm done now.
[ March 15, 2004, 07:41 PM: Message edited by: gtm245 ]
'04 benz...the dealer will do that on schedule for a 10k mile oil change, whatever
'03 Odyssey DuraBlend 5w-20/Fram X2 3000 OCI, give or take
02 WRX - Amsoil Xw30, Amsoil filter, 7500 mi oci.
01 Jeep 4.0l - Amsoil Xw30, Amsoil filter, 7500 mi oci.
97 Taurus sohc v6 - whatevers cheap mixed with left over amsoil, 3000 ocis.
Im going to try to stretch the wrx and jeeps ocis out to 10k with uoas, possibly with a 5k filter change. I want to try some other synthetics too like synergyn and redline.
2002 Dodge 1500 Quad cab truck 4.7L- 15w40 Quaker State HDX and SuperTech ST8A filter OCI is every 3K as I tow a 5300# race car/trailer a lot with this truck.Saturdays oil change was 15w40 Delvac as I can't find the QS anywhere in the 15w40 weight.
1999 Jeep Cherokee 4.0L-15w40 Quaker State and SuperTech ST8A filter.Was using the ST 15w40 oil until Warren became the blender-was waiting for reports on that switch.3K OCI.I may go back to the ST oil,as this is the wife's daily driver.
1971 Dodge Demon drag race car-440 Mopar engine-all out race car. 10w40 Quaker State and Fram PH8A filter.OCI once a month usually or every 4 races.
1970 Plymouth Road Runner 383- 30wt Quaker State and Fram filter,changed twice a year
93 F150 XLT truck-tow package-5.8L autotrans. Castrol GTX 10W30 every 3 to 5 thousand miles.
In the process of a top end open and inspect at 297,000 miles. Oil side looks OK, but I'm AMAZED at the amount of crud on top of the intake valves! My mechanic friend who is letting me use a bay in his shop said it's typical and to be expected. He says it comes from the oil leaking past the stem skirts and collecting/carbonizing(burning) there.
I'll post this as a separate discussion with other questions later on.
1999 Ford F250 w/ 7.3 diesel: Delo 400 for 1 yr. or 10,000 miles. Ford oil filter. Truck sees mostly unloaded hwy. mileage @ 70-75 MPH. 100,000 miles currently on odo.
2004 Toyota Camry 2.4: Toyota oil filters and Rotella 5W-40. Mostly highway @70-80 MPH. OCI 7000-8000 miles.
1995 Jeep Wrangler 2.5: Delo 400 @ 4000 OCI, Purolator oil filters.
1992 Ford Thunderbird 5.0 - 10w30 Castrol Blend
1994 Dodge Ram 5.2L - 10w30 Valvoline Maxlife
2000 Ford Explorer 5.0 - 10w30 Valvoline Durablend
Oil change interval is 5k for each
Filters are Walmarts' Supertech or what they have at VIOC shops.
Update #3
A quick breakdown of oils, filters and intervals. The number in parenthesis is the number of users (vehicles) (). The results are in no specific order.
Oils:
Mobil 1
-5w30 (21)
-10w30 (10)
-15w50 (4)
-0w20 (4)
-0w40 (3)
-5w40 (1)
-10w40 (1)
Delvac 1
-5w40 (8)
-15w40 (1)
Amsoil
-5w30 (8)
-10w30 (4)
-0w30 (7)
-10w40 (1)
-15w40 (1)
-20w50 (1)
Pennzoil
-10w30 (6)
-5w20 (3)
-5w30 (6)
-15w40 (6)
-5w50 (1)
Chevron Supreme
-10w30 (9)
-5w30 (1)
-10w40 (1)
Chevron Delo
-15w40 (5)
Schaeffer
-10w30 (4)
-5w30 (2)
Schaeffer Blend
-10w30 (3)
-15w40 (1)
-5w30 (2)
Castrol German GC
-0w30 (14)
Castrol Syntec
-0w30 (3)
-10w40 (1)
-5w30 (1)
-10w30 (1)
Rotella
-5w40 (5)
-15w40 (1)
Pennzoil Synth
-5w30 (2)
-5w20 (1)
Havoline
-10w30 (5)
-5w20(1)
-5w30 (3)
Redline
-10w40 (1)
Shell
-5w30 (1)
Quaker State
-20w50 (1)
-15w40 (2)
-10w40 (1)
Valvoline
-5w30 (1)
-10w30 (1)
Valvoline Durablend
-10w30 (2)
-5w30 (1)
-5w20 (1)
Exxon
-10w30 (1)
BP Visco
-5w40 (1)
Castrol Formula R
-5w30 (1)
Petro Canada Duron
-0w30 (1)
Valvoline Synpower
-5w40 (1)
Saab Turbo
-0w30 (1)
Royal Purple
-5w30 (1)
Motorcraft
-5w20 (1)
Havoline Synthetic
-5w30 (2)
Supertech
-10w30 (2)
-5w30 (2)
Castrol GTX
-10w30 (1)
Oil changing intervals all listed in miles:
2000 (1)
3000 (41)
4000 (14)
5000 (31)
6000 (21)
7000 (9)
8000 (3)
9000 (1)
10000 (11)
12000 (2)
15000 (5)
18000 (1)
20000 (1) (bypass)
25000 (1) (bypass)
Oil filters:
Wix (13)
Amsoil (12)
Supertech (16)
Motorcraft (13)
Bosch (6)
Napa (5)
Mann (7)
Pennzoil (3)
STP (5)
K&N (7)
Honda (4)
Havoline (1)
Purolator (11)
AC Delco (11)
Proline (1)
Infiniti (1)
Toyota (5)
Subaru (2)
Fleetgaurd (1)
Toyo Roki (1)
Mobil 1 (1)
Merc (1)
Audi (1)
VW (1)
Saab (1)
Mopar (1)
Nissan (1)
Fram (3)
2003 Honda Civic, 3 months or 4,000 miles
Pennzoil 5W-20, Honda or AC Delco Filter
1999 Chevy S-10 4x4, 6 months or 5,000 miles
Mobil 1 10W-30, Pure One, Delco or Napa filter
1999 Izuzu Amigo, 3 months or 4,000 miles
Pennzoil 5W-30 or 10W-30, Castrol filter (.50 at Kmart)
Restored 1974 Corvette. 350 CI V-8. Registered and insured as antique......both carry mileage resrictions.
OCI...1000 miles (6 Months)
Oil...Valvoline 10W30
Filter....Wix
02 Honda Accord V-6
OCI....3750 miles
Oil...Valvoline 5W30
Filter....Wix
This will help boost the RL numbers.
03 Honda Civic
OCI....10,000 miles
Oil...Redline 10w40
Filter....M1
95 Ford Explorer
OCI....8,000 miles
Oil...Redline 10w40
Filter....M1
88 Honda Civic CRX
OCI....10,000 miles
Oil...Redline 10w40
Filter....M1
98 Honda VTR1000
OCI....6000 miles
Oil...Redline 10w40
Filter....Toyo Roki
Update #4
Oils:
Mobil 1
-5w30 (21)
-10w30 (11)
-15w50 (4)
-0w20 (4)
-0w40 (3)
-5w40 (1)
-10w40 (1)
Delvac 1
-5w40 (8)
-15w40 (1)
Amsoil
-5w30 (8)
-10w30 (4)
-0w30 (7)
-10w40 (1)
-15w40 (1)
-20w50 (1)
Pennzoil
-10w30 (6)
-5w20 (4)
-5w30 (7)
-15w40 (6)
-5w50 (1)
Chevron Supreme
-10w30 (9)
-5w30 (1)
-10w40 (1)
Chevron Delo
-15w40 (5)
Schaeffer
-10w30 (4)
-5w30 (2)
Schaeffer Blend
-10w30 (3)
-15w40 (1)
-5w30 (2)
Castrol German GC
-0w30 (14)
Castrol Syntec
-0w30 (3)
-10w40 (1)
-5w30 (1)
-10w30 (1)
Rotella
-5w40 (7)
-15w40 (1)
Pennzoil Synth
-5w30 (2)
-5w20 (1)
Havoline
-10w30 (5)
-5w20(1)
-5w30 (3)
Redline
-10w40 (6)
Shell
-5w30 (1)
Quaker State
-20w50 (1)
-15w40 (2)
-10w40 (1)
Valvoline
-5w30 (2)
-10w30 (2)
Valvoline Durablend
-10w30 (2)
-5w30 (1)
-5w20 (1)
Exxon
-10w30 (1)
BP Visco
-5w40 (1)
Castrol Formula R
-5w30 (1)
Petro Canada Duron
-0w30 (1)
Valvoline Synpower
-5w40 (1)
Saab Turbo
-0w30 (1)
Royal Purple
-5w30 (1)
Motorcraft
-5w20 (1)
Havoline Synthetic
-5w30 (2)
Supertech
-10w30 (2)
-5w30 (2)
Castrol GTX
-10w30 (1)
1000 (1)
2000 (1)
3000 (41)
4000 (17)
5000 (32)
6000 (22)
7000 (9)
8000 (4)
9000 (1)
10000 (13)
12000 (2)
15000 (5)
18000 (1)
20000 (1)
25000 (1) (bypass)
Oil filters:
Wix (15)
Amsoil (12)
Supertech (16)
Motorcraft (13)
Bosch (6)
Napa (5)
Mann (7)
Pennzoil (3)
STP (5)
K&N (7)
Honda (4)
Havoline (1)
Purolator (12)
AC Delco (12)
Proline (1)
Infiniti (1)
Toyota (5)
Subaru (2)
Fleetgaurd (1)
Toyo Roki (2)
Mobil 1 (4)
Merc (1)
Audi (1)
VW (1)
Saab (1)
Mopar (1)
Nissan (1)
Fram (3)
Castrol (1)
[ July 13, 2005, 07:42 PM: Message edited by: Gary Allan ]
