Originally Posted By: LargeCarManX2
Before draining the engine and the oil level is a little low. Add a can of engine flush such as Amsoil or other quality flush. Run for 15-20 minutes at fast idle and drain, change filter, and that's about as good as you can get.
+1M my friend
LubeGard makes an engine flush, too. Good stuff.
FACT: oil add packs suspend junk that you wanna drain out
FACT: when oil suspends the junk, the engine does not have the junk
FACT: When you add new oil, you add new capacity to hold junk
FACT: If you have a reasonable OCI, you will always have enough capacity to hold junk
CONCLUSION: Use good oil. Change often enough. Drain Fill Go.
Best
K
+1M my friend
Best
K
