Originally Posted by Clubber_Lang
Bought an original owner 2004 Toyota Solara 2.4....oil change records every 2500-3000 miles. Car ran ok when I bought it, but had just a *little valve train noise. Nothing too bad.
MMO at 15% quieted / smoothed it out after about 300 miles. This has been my experience over and over with different used vehicles
I wouldn't use it every oil change, but I don't think it hurts to use it in applications like the above, or perhaps every 50,000? or so miles.
Slight oil thinning of 5w-30 in a Toyota (especially in the winter) does not bother me a bit....
We share similar results. I haven't had the need to treat an engine with it in quite a while now, but over the years in beaters, a used car with unknown history, or recommending it to a friend to remedy a problem it has always worked as intended. Having said that it is not going to fix a bad cam, or worn out rings, but in a mechanically sound engine with a ticking lifters, an engine needing cleaning, or had stuck ring/rings it worked.
