What is it about FRAM
KCtom, we have been over this many times......You are fully aware of why Fram is bashed here moreso than others, yet you still continue to argue the same point. Why bother answering your post- the search feature will take care of that most effectively.
Tim H
Quite honestly Tim, no one here has presented any solid evidence against Fram. So to answer your question, No, I do not know why Fram is bashed here. Unless I get some solid reasons, my only assumption must be lack of intelligence. For no intelligent person would make a statement bashing someone's product without a good reason.
rg144
I went to the Ford forum as you suggested. I did a search on Fram. I found no catastropic failures. Some people had had good luck with Fram, others hadn't. The failures were all start up noise related. One person solved his start up the noise by changing from Motorcraft to Fram. One person had start up noise with Fram but said that UAO indicated that there was no excessive wear. Some people had good experiences with Fram.
just what kind of evidence are you looking for? Obviously the many people on here that have found a 'problem' with a fram filter did say only by word of mouth that a filter change cured their problem. That evidence, is apparently not good enough for you. If teh filter caused a massive failure in the engine, then yes, show me some pics, something that proves it. I for one, having had the ADBV problem personally, am not going to take that chance, especially when a poorly constructed, overpriced cannister type filter can be changed to a cheaper, better made product, to cure a problem that never should have happened to begin with. In your second posting you quoted a problem with a guy using a fram and getting noise, but doing a used oil analysis and finding no faults. Do you honestly trust that fact? meaning, to me, just because a used oil analysis does not show damage, did it occur that maybe the additives in the oil have coated the parts enough to prevent such damage showing up? and that by continuing with this 'problem' he lessens the chances of an engine surviving a low oil pressure incident because all his additives have already been used up trying to protect that 'dry started' engine because that Fram had a bad ADBV? in all the other posts, you have Never answered my questions of Fram vs anyhting else? So i will ask once more....Why pay $9+ for that new X-2, when a $4-5 wix or napa or Supertech is contructed as well or better?
if cardboard is that good at sealing the ADBV, why do no other filters have it too? Obviously cardboard is cheaper, so why is EVERYONE else NOT using it?
And why, if the cardboard is so effective, does the much overpriced X-filter NOT have cardboard in it?
As said before...another question is not how well does the Fram hold up to any other filter, the question is on the same engine, How much LONGER would that engine have lasted had it not have to be started with empty oil filters? answer me those questions...i have asked them before, and i have yet to get an answer...convince me otherwise..
Tim H.
I don't use Fram X2 filter. Based on my driving and maintenance habits, Fram does not recomend it for my engine. I use the Extra Guard. I consider those high priced filter a waste of money. Also, I have NEVER advocated that anyone use FRAM. I simply believe that there is no evidence to indicate that Fram filters are anything but a quality product as are the vast majority of filters sold out there.
Also, I did not claim that excessive start up noise can be ignored. I was just relaying the information given in this one particular post. I am sorry that the evidence that this person presented upset you so.
I have absolutely no idea why they chose to use metal endcaps other than the one given by Fram.
Tim H.
One more thing. The peolpe who have had problems with Fram filters report start up noise. I addressed this problem in an earlier post. Please read it.
Tim H.
Cardboad is not used to seal the ADVB in a Fram filter. Cardboard is used as a sealing medium in the filter. But cardboard has been used for years and years as a sealing media. In fact, your car probably contains many cardboard seals.
I will cut and paste an article from yourlast'Fram Battle' :
Another thing you seem to not consider. Take a Fram's filter media. rated for, say, 20 microns. and say, 75 sq inches of total area of media. Can the media filter this 20 micron stuff out? more than likely, yes. Now, take say, a Supertech. rated for, say 20 microns also. but has 100 sq inches of media (cut each one open, or look at the first posting on this subject, you will see more media in the Super Tech) will the Super Tech filter 20? yes, also. OK, both boxes say they can do it, so must be true right? good. Now, take that same Fram and Super Tech filter and run them for 5k miles on the SAME brand oil, engines, driving conditions, etc. Now, it comes down to how much media in the Fram is clooged with 20 micron crud vs how much of the Super Tech's media is clogged with 20 micron crud. A bigger percentage of the Fram will clog before the Super Tech ( I am using Super Tech for Example, because it sits right next to the Frams at Walmart)and go into Bypass sooner. This is #1 for people 'shedding the orange'. the second is problems with ( and well-documented ones- look them up) the ADBV. the cardboard endcaps are simply NOT strong enough to keep the element and core of the filter straight enough so that the ADBV sorta cocks itself on the top lid and ultimately leaks causing the much described, much documented "empty filters when removed" and the "engine rod-knocked on start momentarily and replacing the filter stopped it" syndrome. So 2 reasons of inferiority.
1. the media is smaller in total area
2. the ADBV cannot seal well due to the flexibility of the end-caps
Now the third...
I have read the BS response from Fram about why they went to the steel end-caps on their "higher quality" filters. they say it is a glue issue. Funny how most all major manufacturers of filter use the same glue on their METAL end caps, without a problem. So that tells me the glue used on the Cardboarded filters is inferior in itself, as it cannot handle metal end-caps. cost cutting measure again?
So now I hope you have a better understanding of why the Fram filters are not generally well-liked on this forum. I am sure you have people that went 1 gadzillion miles on their Fram-equipped car. But consider this.....could they have gone 2 gadzillion if they used that Super Tech filter sitting right beside the Orange ones at the local Walmart?.............
This question on the cardboard was answered then. your debate then was that the cardboard sealed as well as metal. Now you say "Cardboad is not used to seal the ADVB in a Fram filter. Cardboard is used as a sealing medium in the filter". So tell me what/where the cardboard is/does/seals?
Yes, people have reported problems with other filters' ADBV..however, it seems there has been an unusually high number of them being Fram. I just think that using an equal amount of filters, more failures of this ADBV will occur with the Fram filter than with other brands.
AS for the mans posting about the UOA, it does not upset me in any way, but does it not fall under the 'I had a friend who/I heard from So-and So who/ I read it on the internet kind of proof?
Ah another Fram filter topic another post by kctom.
If anyone is curious about the Fram's downsides, design problems, construction, or failures, do a search. Kctom, there have been plenty of posts with proof good enough for everyone but you. Obviousely you will continue to support Fram filters forever, but why discredit all the work people have done and the problems people have had? I haven't seen anything that you have posted that is proof that all the points brought up are false.
In case anyone can not find one of these previous posts, just Click here for all of kctom's posts.
-T
Let's turn the question around. It is true that I have nothing to prove my truck suffered any harm in the years I used Frams. Last I looked they were approaching $3 at Wal-Mart. What data exists suggesting my truck would be better off if I spent the extra for the Frams over ST's? I have been using mostly ST's since I cut a Fram apart. Why should I switch back?
The original question was:
Anyone here ever had a engine fail do to a Fram filter?
My answer - no. No additional comments requested or necessary.
quote:
Exactly. I have the same question. Why would I want to spend the same or more $$ for a Fram than the Motorcraft filters I'm currently using? And anyway, I find the orange canister clashes with my underhood color scheme but white goes with almost anything...
Yes, Fram did have a problem with filter failure in the Dodge Ram 5.9L Cummins application.
The filter has since been redesigned and no failures under normal service have been noted since.
I don't understand the constant defense of Fram. Even without cutting one open it's evident they're an inferior product. First of all, I've never had a Fram with a functioning ADBV, at least for their slant six application. Never had that problem with Wix or Baldwin. I dunno about you but listening to those bearings hammer for 4-5 seconds after startup does not give me warm fuzzies. Also engines which develop high startup oil pressures, like the watercooled VWs, do have a habit of blowing apart inferior oil filters, and Frams are notorious for this. Very few informed VW drivers use Frams even though the ADBV isn't an issue for them (right side up filter.)
For my money, it's Wix/NAPA Gold or Baldwin/Hastings. My car is worth too much to try to save a lousy buck by using a marginal oil filter. You think Fram is going to pay for engine repairs on a 16 (or 42) year old car? I don't want to take the chance.
Look at it this way, would you be even reading this message if you didn't care about getting the most from your engine and oiling system? If you are reading this and yet you use Fram, WHY? I admit to being a little passionate about this but I have had nothing but bad experiences with Fram filters and have not had the same experiences with any other filter.
nate
"Anyone here ever had a engine fail do to a Fram filter?"
Older Frams (and maybe newer Frams as well?) were known to perforate their media paper where it contacted the center tube holes, possibly due to insufficient cumulative hole area in the tubes (???), although this wouldn't necessarily cause engine damage. The author of one oil filter survey mentioned that he thought one of his engines failed after a Fram discharged bits of media paper into the lube system. Dissected Frams have also shown cheaply made plastic bypass valves and loose, sloppily-fitting bypass valves wedged into cardboard base plates. Plenty of folks have commented on thin, ineffective Fram anti-drainback flaps and resulting chatter at start-up.
In addition to overall construction quality issues, in oil filter studies Frams frequently bring up the bottom of the pack in terms of total media area. The issue may not be "Will Fram harm my engine" so much as "Aren't there better quality/performance options for the same price?" The answer is definitely yes.
If your criteria is that a filter is good as long as your engine doesn't fail because of one filter, then Fram is OK.
Think about it, if an oil filter failed internally and fully bypassed oil for the life of the filter, would you know it?
Short of an external leak or flow blockage that is serious enough to notice, you have no way of knowing if a filter has failed or not.
Failed ADB valves in Fram are so common that they are almost routine. Many people who have filters that are mounted other than open end up are all too familer with Fram filters draning back into the engine when the engine is off for awhile.
What do you all think about the X2 series? Are they worth the money? Just installed one on my new '04 Malibu. It looks like it flows better than Mobil 1.
