Only a 4.0? How pedestrian.
The MaxLife 10w-40 in my '98 resembles this remark...
Ok thanks. I swore I read that HTHS had a cap for API rated oils because it impacted fuel economy too much.The SAE gives minimum HT/HS requirements for gasoline engine oils.
That's useful info!In 5w30, no. I think API mandates it is below 3.5.
I don’t believe the API does anything like that but I could be wrong. SAE and manufacturer approvals, yes.Ok thanks. I swore I read that HTHS had a cap for API rated oils because it impacted fuel economy too much.
I think I'm wrong about this. However, you won't see API SP 5w30 oils with an HTHS >3.5 because SP prioritizes fuel economy. I'm not aware of any.That's useful info!
I don't want a 5w40, but you got me thinking. I just compared the KV100 cSt of Quaker State UPFS 5w30 to Quaker State Euro L 5w30.Hard to beat Quaker State Euro 5W-40 sold at Walmart. $23 not on sale. Or Mobil 1 ESP 0w30 for usually $27.
Mobil 1 Full Synthetic and ESP in 30 grades meet the performance requirements of SP (LSPI, TGDI chain wear).I think I'm wrong about this. However, you won't see API SP 5w30 oils with an HTHS >3.5 because SP prioritizes fuel economy. I'm not aware of any.
I don't think you really need to read the tea leaves like that. There are very stringent Euro approval tests that are peformed. Just pick something MB 229.5 or .51 or .52, LL-04, or VW 504.I don't want a 5w40, but you got me thinking. I just compared the KV100 cSt of Quaker State UPFS 5w30 to Quaker State Euro L 5w30.
Quaker State Ultimate Protection Full Synthetic 11.7 cST
QSEL 13 cSt
Most other 5w30 USA syn oils are from 10 to 10.5 cSt.
Wow those QS # are good/high cSt @ 100C for 5w30 synthetic oils, especially for the excellent prices they're available at Walmart.
This makes me realize a couple things. There's a definate connection between KV100 high cSt and high HTHS. It appears to me that Euro oils are (at least in part) relying on having higher cSt @ KV100 to get a higher HTHS number.
So I think I'm correct in liking 5w30 synthetic with high cSt @ KV100. In the past I liked it mainly because thicker is less likely to leak in an old car, but now I'm also seeing the HTHS lubrication benefits too.
Of course I also like it to be thin enough at KV40 too.
I think there's a difference between "meets requirements" and "carries approvals."Mobil 1 Full Synthetic and ESP in 30 grades meet the performance requirements of SP (LSPI, TGDI chain wear).
ESP 5w30 for sure has an API license. It is the 0w30 that only meets the engine test requirements, not the bench portion. I believe the 0w30 has a slightly high phosphorus level, which might be considered a feature instead of a bug.I think there's a difference between "meets requirements" and "carries approvals."
I would rather have the 3.5 versus the 3.2 or 3.3!Valvoline FS High Mileage 5w30 has a HTHS of 3.2. The same oil in 10w30 has a HTHS of 3.3. Mobil 1 High Milage in 10w30 is 3.5. All these oils would work well in your application.
Remember I said "Meets the performance requirements". FS for example can't meet the formulation requirements (Phosphorus levels iirc), but that doesn't mean it can't pass the relevant tests under SP. API isn't a high bar and just required a formulation change which includes replacing some amount of Ca with Mg. API SN oils were predominantly Ca only.I think there's a difference between "meets requirements" and "carries approvals."
Good point. I missed that subtle wording difference. Thanks.Remember I said "Meets the performance requirements". This is different than "Meets the requirements". FS for example can't meet the formulation requirements (Phosphorus levels iirc), but that doesn't mean it can't pass the relevant tests under SP. API isn't a high bar and just requested a formulation change which includes replacing some amount of Ca with Mg. API SN oils were predominantly Ca only.
Have to be careful with context when talking about the correlation between HTHS viscosity and engine wear. It has to be looked at under the same conditions, like for instance the oil being the same temperature and under the same shear rate in a bearing or between two moving parts. An oil with less HTHS viscosity under those same operating conditions will result in a smaller film thickness between the moving parts, and therefore have the possibility of more wear. Wear control is all about separating moving parts with an adequate film thickness between parts to minimize rubbing and wear, and also the film strength of the oil which is what mitigates wear when two moving surfaces start rubbing on each other when the film thickness goes to zero.People incorrectly presume lower.HTHS equals more wear. This is inaccurate because engineering (oil coolers, bearing design, oil pump strategy and application(commuter car vs race.track) matter by a lot. However, we like simple answers to complex questions so what feels good along with confirmation bias rules the day.
What is "oil pump strategy"?
And to add, not by much at all. The hydraulic pumping HP difference is hair splitting at best ... running the numbers shows this. Also, variable displacement oil pumps try to minimize oil flow to low as possible. I'd rather have an old fashioned oil pump that pumps way more oil flow than the minimum and I'll take the 0.05 MPG drop in fuel economy.Variable oil pumps decrease power requirements and subsequently reduce fuel consumption.
Here's SAE J300 defining engine oil grades.Ok thanks. I swore I read that HTHS had a cap for API rated oils because it impacted fuel economy too much.
