I’m wondering what happened on the middle of the blade (blue circled area). It looks almost like grease oozed out, but it’s a hard, yet flexible plastic material.
Backstory: this is the original rusty 48” deck of my 1992 JD 240. I bought a used 48” deck from a 265, but I’ll need to replace at least one spindle, as the 265 deck deck sat out in the elements and the three spindles are at varying levels of spin-ability. I’m hoping I can re-use the spindles on my old deck. One has basically no play. The other two (pictured) have a little bit.
I had hoped I could just lube the 265 deck spindles and all, since replacement will be a bear. I tried removing one bolt and could tell I’d end up grinding it off. So, I left them on and successfully mowed my 1.3 acres. However the PTO-to-deck belt is once again expanding and now I feel some vibration under the deck.
This is my first foray into mower deck work, aside from belt replacements. My apologies for the very bad blades on the old deck. They will not be reused.
