I have a 2001 Corolla CE with a 4-speed automatic transaxle, the A245E by Aisin, which is in need of a transaxle fluid change.
The originally recommended fluid for this transaxle is Dexron-III as per this TSB:
http://www.ncttora.com/fsm/2000/Service Bulletins/tc001t02 ATF Fluid Requirements.pdf
Unfortunately as you all know, stock of Dexron-III may be sparse or nonexistent in any store.
Another issue that complicates things is this article/blog posting states that Dexron-VI is fully backwards compatible in GM transmissions, but does not mention if this is true for any others which used older Dexron fluids:
http://www.sandyblogs.com/techlink/2009/05/dexron-vi.html
It also states that licensing for Dexron III had expired back in 2006, and nothing with such a label should be trusted these days.
This thread talks about backwards compatibility, and user Ken2 brings up something in regards to non-GM transmission incompatibility: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1217344
Originally Posted By: Ken2
Dexron-VI is certified backwards compatible only in GM's Hydramatic transmissions. It is not backwards compatible in Allison transmissions, and may not be in transmissions of other brands that originally called for Dex-III or Dex-II.
Licensed Dexron-III is still being made, only now the spec is called Allison TES-389.
I'd fully trust all the unlicensed Dexron products made by any major outfit...Chevron, Mobil, etc.
It wasn’t said in the thread that Aisin transmissions were incompatible with Dexron-VI, but It really leads me to believe that this fluid may only be for GM transmissions.
In regards to this thread:
Toyota T-IV and Dexron III are NOT the same. Neither are the 2000-2002 and 2003+ A245E transaxles.
This doesn’t confirm it, but both listed A245E transaxles have different part numbers.
TRANSAXLE ASSY, AUTOMATIC, 2001 Corolla CE 30500 1A640
TRANSAXLE ASSY, AUTOMATIC, 2003 Corolla CE 30500 1A790
This may be perhaps due to different engine/transaxle mount locations, but also for change in clutch material. Whatever the case, we will not consider these transaxles to be the same.
I have called around, and can only seem to find either the Toyota rebranded Dexron-III, Castrol Synthetic Dexron-VI, and Mobil 1 Synthetic ATF locally. Toyota’s Dexron-III (simply labeled “Toyota ATF”), is plentiful, but very expensive at $13+ per quart, all while still being a standard conventional fluid. Mobil 1’s synthetic ATF and Castrol’s Dexron-VI are $10, and $6.70 respectively. Not only are they cheaper than Toyota’s fluid, but they are fully synthetic fluids as well. What I am unsure of is whether I can actually use anything besides the Toyota fluid in the transaxle without causing a problem.
Mobil 1 only has a recent Q&A covering the compatibility of its synthetic ATF with Dexron-III applications:
http://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Synthetic_ATF_Dexron_III.aspx
Originally Posted By: Mobil1
The new Mobil 1 Synthetic ATF will meet the requirements of Dexron III as the previous formula did. Feel confident to continue using Mobil 1 Synthetic ATF. In the product description we recommend Mobil Dexron-VI ATF for GM vehicles manufactured in 2006 and later. For vehicles older than that, Mobil 1 Synthetic ATF is still a perfect fit.
This once again states it is a fluid approved for GM vehicles which required Dexron-III, but does not specify compatibility with other transmissions which required Dexron-III as well.
Here are Castrol’s claims with their fluid:
http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9012227&contentId=7028225
Originally Posted By: Castrol
• Certified and approved by General Motors for all cars and trucks that require DEXRON®–VI. Also satisfies requirements of DEXRON®, DEXRON®–III H, III, IIE, and II.
Once again, it speaks of approval for GM applications for use in transmissions requiring Dexron-VI, but does not specify if the approval for use in Dexron-III transmissions includes anything but GM as well.
Just to touch on other fluids I would be able to order online, there are Royal Purple and Amsoil synthetic ATF which others have recommended.
Here is Royal Purple’s Max ATF:
http://www.royalpurple.com/products/max-atf-automatic-transmission-fluid/#
The specifications show that it is compatible with Dexron-IIIF/G/H, but not simply Dexron-III which I believe may be different (can someone please confirm this?)
Here is Amsoil’s recommendation chart for transmission fluids:
http://www.amsoil.com/products/transmission/transfluid_rec.aspx
For Toyota, it only shows recommended fluids for Type T, T-III, T-VI, and Toyota WS fluids, not for Dexron-III used in pre-2003 Aisin transmissions on Toyotas.
Amsoil’s specifications for its Synthetic Multi-Vehicle ATF:
http://www.amsoil.com/StoreFront/atf.aspx
Specifications show it is recommended for GM Dexron-IIIH, but nothing mentioned for normal Dexron-III applications. It even shows it is compatible with Toyota T-III and T-IV applications, which are not a compatible fluid with the transaxle in question.
I am aware that Dexron-VI is a less viscous fluid than Dexron-III, as well as a synthetic fluid, and that it shouldn’t cause a problem with use in GM Dexron-III applications because it holds its viscosity better, despite being less viscous to begin with. I just don’t know if any Dexron VI fluid may be used in the Aisin A245E.
I have heard many people using the mentioned fluids, among others in their Corollas with the same transaxle. Nothing I have found has proven to be documented with the change, and following up on it. The closest I could find is this DIY thread where user Crowbar911 states that he’s using Dexron-III fluid, when it’s actually Castrol Import Multi-Vehicle ATF, once you see the photo:
http://www.toyotanation.com/forum/131-8t...ter-change.html
Here’s Castrol’s Import Multi-Vehicle ATF:
http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9012226&contentId=7028224
Castrol Import Multi-Vehicle ATF seems to only list its suitability in applications for GM Dexron-IIIH and prior. He has yet to report a failure with his car’s transaxle after that post in 2007.
I don’t have too much money, so spending less than $13/qt. on a conventional fluid would be nice. I would like very much to use a synthetic fluid, as my brother drives this car. My brother does a lot of stop-and-go driving, goes often on long trips, and tends to delay servicing the car. I’m sure it would help reduce the amount of wear and prevent it from getting too hot.
I will be doing a drain-and-fill at first so I can at least get rid of the old stuff that’s been sloshing around in his box for a while, but just a little down the road actually drop the pan so I can clean that, the screen, and the magnets.
Can anyone shine any light on ANYTHING?
