What do you top off with?
Originally Posted By: TrevorS
A related question: When do you top off? Below minimum only?
This is just what I do:
If I require 0 topoffs to make it to end of OCI, (still above min at end of OCI) then I don't top off.
If I know I will need a topoff, then I check at halfway point of OCI, and do the top off to full at that point. This should mean at end of OCI I should be somewhere min-middle.
If I require 2 topoffs; split the OCI into 3rds. (should be below middle at 1/3rd mark)
3 topoffs I'd put the OCI into 4ths and so on.
I don't have a car that requires 2 or 3 topoffs, perhaps it's time to consider a different oil that doesn't get consumed instead, at this point.
Topoff oil is whatever oil that I don't have enough for an complete oil change, or the oldest oil that I have (of same spec).
Originally Posted By: davebarnum
Whatever's in my garage/trunk.
Does anybody have any real evidence/proof that it should be topped off with anything in particular?
No. This is just an opinion piece.
My last oil change was with Mobil 1 Full Synthetic. I use a quart between oil changes. Top off oil was regular Mobil conventional.
