Originally Posted By: Zaedock
I don't think it would turn over though.
Probably wouldn't you're right!
Originally Posted By: turtlevette
You'd have immediate "cavitation" right at the oil pump gears creating an air bubble and zero oil flow.
Wow, turt, you're actually right. You may now break out the solid-like syrup analogies, and you'd be right on point. Also, two kinds of cavitation, one happening inside the pump and one happening in the pan, considering the pickup tube would probably suck a nice crater which the rest of the pan oil could not refill under gravity alone.
Originally Posted By: Doog
Yeah from a distance...at -22F with a 40w it would crank really slow. If it did start at WOT you would probably blow the oil pump first or maybe throw a rod.
Yup, either of those could happen, easily. I've seen a crankshaft actually crack from a mid-winter startup and redline incident.
All the main bearings would spin out - all the rod bearings would spin out - all the cam bearings would spin out - all the wrist pins would spin out - all the cylinder walls would be deeply scored - and all the valve guides would be shot.
All quite possible, with the main and rod bearings perhaps the first to see major damage. If any super waxy oil got on the cylinder liners, it could subject the ring pack to severe hydraulic forces (also depending on stroke length) caused by drag. Perhaps with a combination of the hydraulic forces and sudden temperature spike of the piston crown, cracked ring lands may ensue.
Originally Posted By: Shannow
a bit cheesy, but...
this video gets me every time!!
valid point though. At the time it was made, 0w30's were apparently "synthetic blends" according to the narrator.
Originally Posted By: SilverC6
Hopefully this isn't an expensive piece of equipment we're talking about.
Haha, noooooo, strictly hypothetical. I made this thread with the intention of facing our worst fears, and of course began with a super extreme scenario. I chose a gasoline engine example because they are not built as strong as diesels and have a considerably higher redline.
Now lets revise the scenario a little bit with the -30C days behind us, and with any oil well above it's pour point what would happen to the same engine is started up at 21C or 70F and pegged to redline with a modern synthetic 10w30, does anyone think the same risks and issues will present themself? (Bear in mind that this too is an extreme example as no self-respecting person is going to just start up their gas engine and peg it at it's redline.)
