Vehicle:
1969 Dodge Charger RT 440/727
Application:
Daily Driver / Autobahn / Performance oriented street driving / Long distance driving / City Traffic
Oil & Fluid Selection:
For use with 727 and Power Steering
https://www.rektol-klassik.de/produ...l-ATF-300---Dexron-III.html&Liter=20
For use with Differential
https://www.rektol-klassik.de/produ...-SAE-80W-90---API-GL-5.html&Liter=20
For use with 440
https://www.rektol-klassik.de/produ...SAE-10W-30---API-SE-CC.html&Liter=20
Antifreeze / Coolant
https://www.amazon.de/Mopar-K%C3%BChlerfrostschutz-50-785-MS-9769G/dp/B007O3YFY8
Brake Fluid
https://www.moparshop.com/Online-Shop/OEle-Dichtmittel/1836/Bremsfluessigkeit-DOT-4
Notes
I came up with this selection doing research.
Doing research i noticed that there is not really a "one size fits all" solution and that there are endless debates about the right oil going on.
Thats why i also specified what the car will be used for.
I did not find much about what oil to use in the differential. Hope i picked the right one?
I choosed to go with Rektol for all the oils in the car because i already used their products in the past and always worked out great.
Also like the idea of just using oil from one brand.
So if possible i would stick with this brand for all different oils i need, except i need a oil they dont offer.
I know about this expensive evans waterless coolant.
But as i said its pretty expensive so im not sure if its worth it.
So what do you think?
Did i picked the right stuff or would you replace one or another of the products mentioned above?
