I took a vehicle to be restored to a shop in 2018. The engine was not going to be used. It was a great running engine. Well, plans changed and we are going to use it. So it sat in a non-insulated, not climate controlled shop all this time. Did not even have oil in it as the oil pan was replaced just prior to taking it to him.
So last week the shop tried to start it for the first time after all these years sitting. Pulled valve covers. Said rockers are just flopping. So he said they were going to adjust the valves and try again. (Not sure you can adjust them??) Then he called to say a lifter is likely broken or cam lobe worn as #4 had a rocker that's barely moving. It makes no sense to me. I've been doing a lot of thinking. I'm no mechanic. But I do have what u feel happened in my mind. But to keep from influencing ya'lls opinion, I want to see what y'all think first.
Oh, he said when the engine was cleaned in a vat that whoever did that apparently did not clean the residue good. The oil ports were clogged. The lifter was dry. But that engine was rebuilt in late 1990's to early 2000's probably and 5000 miles ago. I've owned it since early 2000s. Hasn't been rebuilt since i had it. If that was the case, shouldn't that issue have arose before now?
He said they put a set of lifters in it yesterday and replaced 5 or 6 push rods that were clogged.
I'd love to hear what y'all have to say!
