What can Valvoline do to top Restore and Protect?
Since Valvoline Restore and Protect has been their game changer, where does Valvoline go from here?
Not sure if they can top it
Guess they don't need to
I'd assume they'll continue to capitalize on the product as much as possible.
They have lots of weights to fill in, -40, -16, -8
Valvoline Restore and Protect gear oil.
Valvoline Restore and Protect grease
Valvoline Restore and Protect antifreeze
Valvoline Restore and Protect motorcycle products
Valvoline Restore and Protect battery cleaner protector
Valvoline Restore and Protect door gasket cleaner protector
Valvoline Restore and Protect windshield fluid
Valvoline Restore and Protect tire cleaner protector
Valvoline Restore and Protect plastic rejuvenator cleaner protector
Valvoline Restore and Protect down there-there cleaner protector
Valvoline Restore and Protect rim cleaner protector
Valvoline Restore and Protect seat cleaner protector
Valvoline Restore and Protect tool cleaner protector
Valvoline Restore and Protect trash can cleaner protector
Valvoline Restore and Protect screen door screen protector
Valvoline Restore and Protect tile cleaner protector
Valvoline Restore and Protect asphalt roof cleaner protector
Valvoline Restore and Protect dash board protector
Valvoline Restore and Protect concrete cleaner protector
Valvoline Restore and Protect driveway cleaner protector
Valvoline Restore and Protect oven cleaner protector
Valvoline Restore and Protect hand cleaner protector
Valvoline Restore and Protect engine cleaner protector
Valvoline Restore and Protect outdoor grill cleaner protector
Valvoline Restore and Protect phone screen cleaner protector
Valvoline Restore and Protect metal roof cleaner protector
Valvoline Restore and Protect wood/metal shed cleaner protector
Valvoline Restore and Protect infected wound cleaner protector
Valvoline Restore and Protect floor mat cleaner protector
Valvoline Restore and Protect grime scrub cleaner protector
Valvoline Restore and Protect garage/house cleaner protector
Valvoline Restore and Protect marine cleaner protector
Valvoline Restore and Protect ATV cleaner protector
Valvoline Restore and Protect plastic headlight cleaner protector
Valvoline Restore and Protect shower cleaner protector
Valvoline Restore and Protect scan tool cleaner protector
Valvoline Restore and Protect toilet cleaner protector
Valvoline Restore and Protect mirror cleaner protector
Valvoline Restore and Protect parts washer cleaner protector
Valvoline Restore and Protect wood cleaner protector
Valvoline Restore and Protect new tattoo protector
Valvoline Restore and Protect air hose cleaner protector
Restore and Protect bad cut cleaner protector
Valvoline Restore and Protect down there rejuvenate has taken the sales lead
Shhh don't give them any more ideas.
I asked Valvoline if they were going to make euro version of Valvoline Restore and Protect, this is what they said.
Restore & Protect has only been tested and approved for API SQ and ILSAC GF-7A requirements for gasoline engines. It has not been formulated nor tested to meet ACEA specifications or European vehicle OEM approvals for European gasoline or diesel engines.
We will forward your inquiry to our marketing team for future product consideration.
Maybe if enough people ask for a euro version, they will?
They sort of already do, minus the approvals. I think they don't want to disclose formulation secrets or, there may be something off that (such as too high of xyz additive etc.) that prevents them from getting official approval.
Knowing Valvoline has an extensive test lab and their director worked at Infineum, I'd be ok taking their recommendations.
https://www.valvolineglobal.com/en-eur/restore-protect/
These are questions I have… During the “restore” phase, what exactly happens and are any contaminates loosened and pumped across wear surfaces? Then does the “protect” phase keep the wear surfaces from scratches etc. from the loose contaminates that would otherwise have set harmless in the recessed areas for the life of the engine? If the additive package is so strong that it does loosen contamination from these areas, how does it react on crankshaft seals etc. Edit: dwcoopless will point out any misspellings, vocabulary mistakes, and anything that he determines is incorrect. Thanks!
This is a question I have… During the “restore” phase, what exactly happens and are any contaminates loosened and pumped across wear surfaces? Then does the “protect” phase keep the wear surfaces from scratches etc. from the loose contaminates that would otherwise set dormant in the recessed areas for the life of the engine? If the additive package is so strong that it does loosen contamination from these areas, how does it react on crankshaft seals etc.
It works by chemically dissolving carbon. It cleans and protects at same time. No issue. They know this because they tested it in actual engines for close to 1 million miles before releasing it.
That only appears to be in Europe, as I pulled up Germany and they have it in that country’s documents from Valvoline. Notice that 5w-40 jugs says 5 liter jug vs USA at least 5 qt jug. There is no 5w-40 documents for any country in North America.
