I know that a UOA will give me a better reading, but I would like to at least use the OCI formula to calculate an approximate initial interval for using with my stash of green GC. I have seen several different "C" numbers quoted for GC in my searching on the BITOG site. What is the general consensuses of the "experts" here; 50, 60, 80, ?
For my '01 Buick Century with the 3.1L V6 engine using the larger PF-52 size filter, the formula looks like this;
mileage = (C)(26.2 MPG)(4.5 qrts)(187 ci) / 170 cHP rating
Since I also chart every single fill up with; date, mileage, trip od reading, gals, price and MPG rating per tank full, I can also use this formula as well;
gallons consumed = (C)(4.5 quarts)(187 ci) / 170 cHP rating
I have a 20 mile commute each way to work, of which 75% is on the highway, hence the good MPG readings over the past 5.5k miles or so. Since I have an ODB-II scan tool, I will also need to compare the results from the formula with what the OLM system has to say as well.
Thanks.
Thanks.
