What are you working on today?
Replaced rad cap, now the system could actually hold pressure. Then a radiator side tank let go. Fixed that. Then the plastic t-stat housing let go.
the radiator in this thing is original. The OEM Motorcraft cap has been holding pressure but there’s a crack on the big seal.
  • Wow
Reactions: D60
I predict radiator failure soon. You heard it here first. Not wishing this on you.
I built a basic tube bumper for this '02 ;)
Adjusted the valves on the scooter. Of course ordered a set without a 0.12, only .10 or .13. The intakes the .13 was tight but ok, the exhausts even the .10 wouldn’t ft. Adjusted them out a bit. Changed the oil after, 5w40 Mobil Delvac.
  • Like
Reactions: D60
New vehicle purchase, my local county retired a 2015 Grand Caravan. Drove it to the ranch from the county annex. 104k on the odometer, everything works. New Walmart AGM battery installed. I need to replace the passenger side headrest, spill/fill of the transmission, brake fluid and thats about it. Will take a closer look at the oil cooler but I think its probably ok. It will be assigned to one of my kids in the near future.
Had one of these as a loaner. I loved it. Loved it. It had the lighting package and roll down windows in the back and got killer gas mileage, mid-upper twenties. If I needed a van and couldn’t have a newish sienna (which I think are superbly executed), this would be the one.
This is the third Pentastar Caravan my immediate family has owned, and my parents bought every generation since 1990. The first one (fully loaded RT) had a cylinder head failure around 70k. We eventually sold it off, Dodge did replace it under warranty. Our ranch property has a 2014 with only 48k on it, zero issues. I have 3 kids, so yet another van might be in the future as they will be off to college soon.
My current "big" project is redoing the interior of the NSX. Just about everything I've pulled out has had broken tabs, clips, etc. I will be working on either repairing or replacing all of it. Some of it will be pretty simple, some of it I can get new, and some of it will probably require 3D scanning and printing, which will be a new skill for me (or I'll pay someone).
Yesteday, I started work on recovering the seats. Definitly not finished, but the leather is in position and I'm hoping that a few days in the hot shop will stretch it a bit!
2005 Tundra:
-installed a Ram phone mount on the ash tray. They make -- or at least used to make -- a right angle bracket that clips on the front of the ashtray and creates a flat, vertical face with slots for the ball base.
The fiberglass-esque material was NOT taking wood or plasti screws, so I finally tapped it 8-32 and this worked extremely well. @Tomioka
Also got his Wolfbox installed (has FlipPac camper)
Going to start changing the water pump and raidator on the grand marquis today.
I noticed it's been running warmer than normal and the fans were running a lot more than I ever remember. Threw a new thermostat and flushed the radiator the other day. So. Much. Sediment.
We had a heat wave monday and tuesday. Tuesday I tested how good the head gaskets are. It went into failsafe cooling a few times. I could keep it at 235F if I ran the heat full blast but that was not ideal. Even going down the highway at 65 it was running 230-235
Guess I still know how to do this stuff. Venza got some fluids front to rear. Brakes are next and another coolant dump and thermostat and cap replacement then this thing will be gtg for college when my daughter flies the coop.
$16.80 worth of transmission fluid for a full flush. Shop the clearances and stock up.
What year Venza? I was just talking to a woman today with a 2010 who wants to ditch her 20s for 17s. Ever looked into smaller wheels?
2009. Never looked at smaller wheels. This set of GY Comfortdrives was $1300 with the alignment. I spent $2800 on tires in a week. Have to buy some for the Wife’s QX60 in the next month or two and that will probably be another $1400-1500. I don’t cheap out on tires. Maybe I should but I don’t. Weather is too unpredictable.
Put new 3D printed (from ebay) tailgate bushings in the '05 Tundra
He picked it up and wanted to ramp it to check rear shock length. While difficult to fit in a toolbox, the ramp is an incredible tool to watch suspension behavior/limits
Step one on the task list at my parents, fixing the tiller.
Its an AYP built Poulan rear tine rototiller. It has a B&S 850 series engine. Last used in May on the garden. Received fresh fuel, stabilizer and fuel system cleaner. Had run decently and then began surging and stalling.
Today, changed oil, greased the chaincase, aired the tires and cleaned the carb. There was sediment in the bowl and main jet partially clogged. Simple fix and it runs like a top.
Wow, the in-dash/under-dash lighting work in that vid is incredible.
I have not done this particular job but I promise you it would have taken me six hours because I'm just that good.
I *almost* had to do the heater core in the previous gen Focus (2009) which requires complete dash (and usually front seats) removal. They sold the car before we got there, and I can't say I was upset.
I did the blower motor in a 2009 Mazda5. Major hassle ... front seats out, remove accelerator pedal assembly, remove brake pedal assembly, glove box, all sorts of plastic trim, and under the hood, battery and case and associated ECU, etc. etc.
Took me forever - maybe 4x book time of 4.x hours.
If I ever do it again, I might get it down to 2x book. 😜
And then about six months later I had to replace the clutch master cylinder. Not as bad, but easy. Yeesh.
  • Like
Reactions: D60
My son installed MPI on the GTI yesterday and is wrapping up the odds and ends. Neon green fuel rail, injectors, and tons of wiring and pinning wires to the ECU and power tap in the fuse box. He ordered a new MPI intake instead of drilling the holes into the existing one. While the intake was off the intake valves did not look too bad for 18k miles so we didn’t clean them and will let the 93 octane from the MPI to clean them up.
