What are you working on today?
My sons 2002 Saturn SC1. Needs a water pump.
Got the old one off. New one arrives tomorrow am.
Grabbed the shovel and continued digging for long enough to surprise myself … 45 minutes? Working towards a tool shed.
Sprayed weed n feed, mostly for the “weed” part.
Neighbor crashed his clown car, I was invoked to get it back on the road in a hurry
It damaged the core support, drivers side headlight, smashed the cooling fan into the cat, wiring damage, etc
Warning: this is a temporary measure
Professional body men look away 😒
Got medieval on it with a giant prybar, enough to get the radiator back where it belonged, and opened enough space to extract the broken fan
After swapping in the new fan, it still didn't work
The low speed resistor was cracked in the accident, had to order one for an Aveo
The high speed J case fuse blew, and he had swapped the relays when "checking the fuses"
After much bi directional controlling and power probing, I had a cooling fan again
A pair of light bulbs, some more prybar time, fiddling with the hood latch, and a few zip ties
It's "together", in the sense that nothing's loose, and nothing's gonna fall off
This should get him by until a core support and headlight come in
And an OCI, which is quite easy on this little 1.4
Not attractive but functional 🤷‍♂️
It actually drives fine, not even noisy with the panel gaps 🤔
Replaced a sad-looking yet only 2 year old Dayco radiator hose on our WJ. I noticed it during my semi-weekly oil level checks and was shocked at how bulged the hose was, especially since I was 99% sure I'd replaced it when I did the radiator. Looked back at my RA purchase history and sure enough, there it was. It wasn't even a closeout item, just regular stock.
I drained out enough coolant to prevent any spillage and slapped an AC Delco hose in as a replacement. I actually like the fitment of the Delco better, the curve clears the power steering hard line at a much better angle.
2017 Ford Focus ST, 30.7K.
Oil change, tire rotation, cabin air filter, spark plugs and drain/refill MTF.
Ford calls for plugs every 100k with no time limit. Given the age, the owner agreed with me that it’d be a good idea to replace. I was surprised AutoZone had them in-stock at a lower price than Rockauto.
Replaced all body mounts on '14 F350 CCLB. I used SPE as they seem well-regarded.
I was able to do it 100% on the lift, which was great to stay on my feet. Both of my trans jacks are 1/2t and would bypass at the center mounts. If this looks sketchy, that's because it is
Did the unthinkable and let someone else work on one of my vehicles today... had a shop do a 4-wheel alignment on project Volvo. I've had excellent results from these guys in the past, and today was no different.
I'd installed front quick struts and a rear lateral arm, so it was a full on 4 corner adjustment. The before numbers were surprisingly good considering I just eyeballed things, they had to tweak the rear toe and made a few adjustments to the front but otherwise everything looked great. I was hoping for confirmation that there were no other tweaked suspension parts, so now that that's cleared I can get a set of tires on it and list it for sale.
I finished up the dump truck repairs in the dark on Friday night and have been working it hard this week. Everything went well. New front springs, pins, U bolts, kingpins, shoes and drums, wheel seals and hub caps.
Generally speaking it should have an alignment after all this but I’ve had some very poor experiences with our local truck alignment shops. A lot of times they drive worse after than they did before. In this instance, I didn’t replace any “adjustable” parts except the king pins which only adjust up and down to set the amount of play in them. I will monitor the tire wear and if there’s an issue I will have it checked. The steering wheel is slightly off center now but the truck seems to be driving fine, I’ve put around 600 miles on it in two days. If there’s no tire wear issues present then I’m going to pull the steering wheel off and re-center it and call it good. As a trained technician I know this isn’t the right answer but in an extremely rural area you have to make do with what you have or don’t have.
Sitting on the side of the road once again. This time with my 2017 Mack. Relay valve started dumping air while headed to pick up a load of seed a couple hours from home. Got someone bringing the parts and hopefully be back on the road in a couple hours.
