MolaKule
Staff member
Transferred to Transmision, ATF, Differential, etc.
Common, man!
Did you do it from the top or bottom?Finished the starter on my sons 02 crv. Pretty lousy job. I thought when I did it 22 months ago I was set for the rest of ownership. Nope, thanks to a Made in China AC Delco starter. Didn't even want to warranty it. Went with a Denso this round. I really hope I'm not doing it again.
Bottom, it's doable if you have normal sized hands. I'm not taking the intake off. Take off the knock sensor or else your extension or ratchet gets stuck when removing the invisible top bolt.Did you do it from the top or bottom?
I did mine from the top this year and it wasn’t bad at all. However, if I had a lift or a good, safe method of jacking it up, I’d try from the bottom too….Bottom, it's doable if you have normal sized hands. I'm not taking the intake off.
For a crv no jack is necessary, just lay on the ground. It is irritating working in the tiny area but so is breaking plastic clips removing the intake.I did mine from the top this year and it wasn’t bad at all. However, if I had a lift or a good, safe method of jacking it up, I’d try from the bottom too….
