Today - finished up a front brake job on the battered 99 Dodge Ram 1500 5.9 V8 so we can use it for trash runs.
Brakes were burning and dragging on the last trash run, and the heat and smoke coming off the right front told me where the fix was needed. Rather than fix what was there, with melted brake pad material on the rotor, I ordered up new rotors, pads, and calipers.
It all went on, and I found the real issue last evening. The right side brake hose was blocked. No fluid whatsoever. Driver side was ok.
This morning I ran and picked up a new hose assembly and put it on. My guess is that the heavy rust on the hose mounting points crushed the hose shut. Using the brakes after many months of sitting locked up that caliper and burned up the pads.
New hose (I will likely replace the driver side hose later) and a bleed and it’s all good again.
Those brake calipers, they were probably working but they should have been changed out. They looked like they were plucked from the Titanic’s debris field.
