1993 Volvo 240 sedan, 211,597 miles
New rear Ate rotors and Akebono pads. Bleed all calipers, Ate SL Dot 4. Snow tires.
Not with that mess.Did an oil change on families 2020 Cadillac XT4, because I'll be ****ed if I'm gonna pay $95 at the dealer
Cadillac only gives you the first service free on MY19+, cheap bastards
We've had it about 18 months now, just turned 7k on the clock
That being said, it's a fairly easy change once it's on the ramps, it's a plastic oil pan & drain plug (Ford esque), but the plug is parallel to the ground, it only takes a 3/8 ratchet drive to quarter turn it out
But beware, warmed up 0w20 will gush out and quickly overwhelm even the deepest oil pans, and splash everywhere
It's a very large drain hole, it's done in seconds
On went a new PF66, and 5.5qts of AmazonBasics Dexos 0w20, and an EPAuto cabin filter
Total cost for service: $51
I aired up the tires, and took it for a wash and vacuum
Aren't I just the best grandson?
I'm convinced there's no clean way to drain it on the groundNot with that mess.
Looks like a nice Dodge Magnum (least what it’s called here in U.S.AA Toyota Dyna - I guess one of these would be uncommon in the US...not that common here either. Engine is behind the front axle.
This you might recognise, and not common here.
It's going in this, and I'm not looking forward to it. Started on friday, problems already...
Maybe you could just buy one of those cheap tarps from HF and lay it under there when you change the oil. At least the splashing oil will be on the tarp instead of the driveway.I'm convinced there's no clean way to drain it on the ground
If your on a lift, and you have the big rolling oil catch can that you can put the splash reducing mat in, your fine
At home, on ramps, even with a decent size pan, it just comes out too fast, it's a very large plug and drain port
I'm considering a Mityvac now
It's interesting that it has a Chrysler 300 front and a Magnum body. I like it.Looks like a nice Dodge Magnum (least what it’s called here in U.S.A
I believe WIX now makes a 10351 or 10473 spin on filter for that SUV. Sorry, not 100% certain as not at work but we use wix on thoseDid an oil change on families 2020 Cadillac XT4, because I'll be ****ed if I'm gonna pay $95 at the dealer
I just use one of those big cookie drip pans from AZ to keep the mess to a minimum.I'm convinced there's no clean way to drain it on the ground
