What are you working on today?
Going to finish the spindle replacement on the C10 today. Will also repack the wheel bearings and change the oil. I'm supposed to have a 94 Econoline coming for an oil change as well around 11. Got all my apartment cleaning done yesterday afternoon. I've got to do better keeping up on that. 😬
Yesterday afternoon the Econoline returned with a coolant leak. One of the heater lines to the rear under the van developed a hole and was shooting coolant all over the front of the gas tank. I found where the heater hoses branch off under the hood, disconnected them and looped them together. The front on the gas tank will have to be dropped to repair the line. The customer decided to wait about fixing it since warm weather is here, and we will probably repair it in early fall.
I'm supposed to have a Buick Lacrosse coming in for front brakes and an oil change this morning, and someone is dropping off a 97 Z71 for an oxygen sensor this afternoon.
Today I've got to carry all my waste oil to auto zone for recycling. I took in a 95 Chevy Corsica for Monday for an oil change and tire rotation.
Yesterday I did an exhaust repair to the 2006 Corolla LE. I fixed it using Permatex Muffler & Tailpipe Putty, part # 80333, followed by FiberFix Heat Wrap exhaust tape. The car had gotten very loud recently. To locate the leak I put the hose of the Craftsman 2 gallon portable shop vac in backwards so it blows, and put it in the tailpipe, and sealed the opening with duct tape. Once I turned on the vacuum cleaner and got under the car the noise and airflow directed me to the leak. Air and noise was blasting out of it. There was a jagged 1"x3/16" radial hole in one of the exhaust pipes at the edge of the joint where it fits inside one of the larger pipes,this part of the exhaust is before goes into the angle pipe and into the muffler. It was just in front of the rear passenger wheel. For such a small hole it was quite a loud and raspy noise with the car running and driving.
I cleaned the area thoroughly around the hole using and all sides of the pipe several inches away from the hole, using a steel wire brush and Simple Green to get rid of all the loose rust, dirt and scale. I would recommend do not spare time on the prep. Then followed it up with 91% alcohol on a cloth to clean it of dust and dry . For this I had my son helping by kneading the foil packet of Permatex putty for several minutes which is essential before using it, then squeezing the putty onto a wooden coffee stirrer each time I used the putty, passing him the empty stick over my shoulder. It was useful to have an extra pair of hands while under the car because it was cramped the putty starts to set up after a few minutes. I started by filling the the hole itself the narrrow part first, and building up layers and layers of the putty over the repair and on on either side, and also sealed around the pipe seam itself for good measure. I did not spare the putty on this. There are (2) 2-ounce packets and for the repair we used most of one packet. By the time we finished the putty was getting thick and harder to spread so did not finish the packet. Then I heated the putty for 8 minutes with a heat gun on 750F degrees setting. At that point it was dry to the touch, not tacky, smother and shinier but still slightly flexible. The Permatex putty is rated to 2000 degrees F.
Then I used the FiberFix Heat Wrap exhaust bandage. It is rated to 850 degrees F. With this you really need to work quickly. It's a 70" roll of seemingly fiberglass mesh tape gooped in sticky, red epoxy resin. The kit comes with rubber gloves but I had my own. You remove it from the pouch and must immediately soak it in a bowl of warm water for 5 seconds. This activates the glue. Then starting where the crack had been I wrapped it around where the crack had been and extending out several inches. Around the repair itself I wrapped it 5-6 times as recommended. As soon as I wrapped it you could feel it sticking to the Permatex putty and sticking to itself tightly. Wrapping it tightly is the key. It does not shrink during the curing process but it hardens quickly you have little time to work, and you have to use the whole roll at once. It is no exaggeration to say you only have a couple minutes after dunking it in the water, to get the FiberFix on there and tightly. They include several feet of a 3/4" wide aluminized, paper backed tape just to wrap around the exhaust tape to further tighten it before it cures. I found it fairly useless, does not stick to the Heat Wrap at all and barely sticks to itself, but used it anyway. Then I heated it with the heat gun in two, 10-minute sessions. It cures by heat. Then took off the aluminum tape. The directions say start the car and bring to an idle for 10 minutes, or else use a heat gun. I did not want to put exhaust pressure on the putty or the tape so soon after installing it. After the heat gun, and letting it cure an additional six hours, I then started the car and idled it for 15 minutes. No noise whatsover. I let the Corolla sit overnight without driving it, and took it out for a short trip at 10:30 AM this morning, parked at a grocery store for an hour, and drove home. It's completely silent. I was thinking about later covering it with an aluminum can and hose clamps to further reinforce it and seal against weather, but it seems like a bit of overkill.
New clutch, new front/rear end brakes, complete fluid flush (coolant), power steering, brake fluid, transmission fluid change.
~Added MILITEC1 to transmission fluid, power steering, and engine oil.
Finally finished BMW interior this AM, Coverlay dash skin came out great, PITA, but great. Recovered parts of the console and located some period NOS gauges that are about as close a match to the cluster as I am going to find short of the hens teeth originals. Took about 2x as long as I expected, but that happens. Time to give her the cleaning she needs....
Then brakes on the 996....
My dad needed my help working on a helicopter this morning, then we both worked on our dualsport bikes, went and got insurance for them, then did a 4.5 hour ride, not including the 1 hour lunch stop we took. Part of our journey was down railway tracks, for about 47 kms, what an awesome ride. I should be in the shop working on my Gixxer1k, instead of wasting time on my tablet procrastinating.
Got the oil changed in grandma’s car and mower today. It’s a pain having to take everything to her house to do it. Usually she brings her car to my house but while I was there I just went ahead and done it since it was already 150 miles past due. She lives about 45 minutes away.
Today at my job, worked on 1 zero turn mower, 2 quads, and 4 motorcycles. Most enjoyable job was doing the top end of a 2014 Yamaha YZ 250, new wrist pin, piston, and rings. Changed the gear box oil, after installing a new clutch. Curse wrist pin clips every time, the rest is easy. Riding and racing 2 strokes for years, top ends and clutches was a regular part of their maintenance. This guy needs to clean and better oil his air filter more regularly though. I noted that on the work order, and although he didn't request it, I serviced that as well.
Oil change and tire rotation done on the 95 Corsica. Oil change and grease job done on a 77 Coupe DeVille. Tomorrow I have a 76 Eldorado coming for oil change, front brake pads and grease job. Wednesday I have an 02 Mustang coming for oil change and tune up.
Since my boss gave me spring break off I’m working on the 1990 Mazda trying to be able to get it down to my house to work on it more. It’s sitting on the end of my road right now and a cop drove by and was eyeballing it so I probably need to get it moved. I’m putting fresh gas in next to see if that helps.
Oil & Filter on my QX60. I used Pennzoil Platinum 0w20 & a Mahle OC711 filter that I had from my stash of filters for my previous '13 Maxima. The correct Mahle for the direct injected VQ35DD - 2019 QX60 is OC575, but the OC711 is just 10mm taller...otherwise it fits just fine. If it gives me any noise or concerns, I will swap it for the proper OC575.
You don't know until you try right?
Yesterday I got all the old gas drained out of the truck and today if the rain stops I’m going to put fresh gas in and hit the starter and try to get it moved down to the house then I’ll have to do rotors and calipers as the rotors are very grooved and the calipers are both sticking probably from where it sat outside for a couple years. Possibly have to do pads too and I’ll have to do the starter as well.
