2003 Ford Ranger 2.3L/5R44E, Pulled the trans to find the coolant leak which of coarse was the bypass hose. Well that's what you get when you install a engine engineered to be transversely mounted & put it in a RWD pick-up, It did need a rear main seal though.....
Waiting on parts.
2015 Ford Edge, 3.5L/6F50, 123,000, Auction Rat.......TP Sensor & Throttle Control Motor DTC's.
PCM, Throttle Body, & Throttle Body Connector Pigtail have been replaced....Looks like Ford parts were installed?
Had a little trouble getting it to act up & set DTC's, Did it one time upon hard acceleration from a stop, But could not recreate it upon repeat attempts & I'm not going to keep beating on a car.
Wiggled around the harness & it again acted up once & I could NOT repeat it
. Load tested all the Throttle Body circuits & they were good.
Finally found the smallest of rub-throughs in the tape covering the harness that runs along the driver side end of the front Valve Cover, The big clue was a Valve Cover Bolt had its Hex worn down just a little on one corner & it was real shiny...Almost polished appearance.
Fixed the rub-throughs with some liquid electrical tape, Split a piece of 3/4" heater hose & placed it over the harness where the valve cover bolt contacts it, Re taped the harness with some Tesa Tape.
