What are you listening to right now?
Clash Sandinista, full LP on vinyl. 1980. Three vinyl set absolutely filthy foul. Needed soak and multiple cleans. Needle STILL loads up 2-3X per side. Seems not huge damage though. 45 years old.
Topper Headon, props for his drumming.
Grover Washington, jr. Winelight.
Was unboxing my old albums and found this unopened from 1980! Lol.
Great sound from my system. A few pics, if interested.
Tell me about the amp!
How old? Where made? Watts? Noise etc
Fine looking sub cabinet
Amp Hafler DH220 modified by Musical Concepts. 100 watts per channel into 8 ohms
Preamp Hafler 110 also modified by Musical Concepts.
Made in the USA
Specs:
Model Hafler DH-200
Type Solid State Stereo Power Amplifier
Power Output 100 watts per channel into 8Ω
Frequency Response 10 Hz to 40 kHz
Total Harmonic Distortion 0.012%
Damping Factor 50
Input Sensitivity 1.5V
Signal to Noise Ratio 100 dB
Dimensions 16" x 10.5" x 5.2"
Weight ~26 lbs (11.8 kg)
Back in the day, they replaced components they felt were inferior with higher quality.
Speakers Canton Plus S satellites with passive subwoofer.
Turntable Luxman PD 284 with Ortofon Red M2 cartridge. My old Shure VR15 bit the dust! Still breaking it in but very happy with this entry level cartridge.
Monster cable interconnects.
I went down the audiophile rabbit hole a bit back then! Fortunately I regained my sanity before spent my entire retirement savings LOL
I forgot just how good analog sound is!! The sound stage is amazing.
This system is circa 1980-1985
Made in the USA
Specs:
Model Hafler DH-200
Damping Factor 50
Wow. Very nice.
Can you get a close-up shot of the pre-amp? (I won't ask for rear panel shot hahahahha. maybe sometime)
Do you have two phono inputs? MM/MC?
Input in the preamp is MM only. Could have had it modified for MC back then, but didn’t want to spend the extra dollars. Never could have imagined I would ever be able to afford a system that could take advantage of a MC cartridge.
Well I agree MM v. MC. The new MM cartridges are every bit as good as MC and whole lot less $. All because new small magnets.
Anyway, what is that button and the line by PHONO on the input selector???
Allows you to run two turntables. The button selects 1 or 2. The line just points you in the right direction.
