Give me the pony style on this. I've titrated aqueous solutions with boiler chemistry ..but just how does one get indications of neutralization in motor oil?
We would hit the sample phenolphthalein which would either be invisible or turn it red depending on the polarity. You would then add acid until it either disappeared or appeared (another reagent was added).
Yep. You'd need some kind of pH indicator in there so you can see when it becomes neutral. Phenolphthalein is good for water, not sure what kinds are oil-soluble, or how easy it'd be to see the color change in a motor oil.
TBN is a measure of the acid needed to neutralize some or all the bases present in the oil sample. It is expressed in mgKOH equivalents per gram of sample.
The phenolphthalein method is a colormetric titration and does not give a true TBN.
TBN is determined using a slow potentiometric titration with an acid and the pH is plotted. The end point is an inflection in the pH plot or, if no inflection occurs, a standardized pH. The oil sample is dissolved in an organic solvent.
Different TBN methods use different acids and solvents, and give different results depending on the ratio of strong and weak bases present.
