For the most part, it's the VI improver that shears over time in an oil, which results in the oil dropping in grade, say from 50 to 40 or 30 wt. All things being equal, the bigger the spread between the low temp viscosity and the high temp, the more VI improver needed. Thus a 10w30 oil will require less VI improver than a 5w30 and therefore should be more "shear stable."
But with motor oils, all things are rarely "equal" (especially when it comes to synthetics) and that's where it can get confusing. Because of the high natural VI of the PAO and esters used in Mobil 1 oils, what I said above sometimes doesn't apply. For example, there is good (though mostly anecdotal) evidence that Mobil 1 0w30 and 0w40 have LESS VI improver than the 5w30 and 10w30. The wide range in viscosity with these oils is accomplished primarily with the blend of high VI PAOs and esters in the base oil makeup. The 0wXX grades of Mobil 1 are their most advanced formulations.
Of the more "traditional" grades of Mobil 1 (5w30, 10w30, and 15w50), one would expect the 10w30 to have the least VI improver, though it could very well be the 15w50. Mobil does claim that its Mobil 1 20w50 motorcycle oil has NO VI improver added.
Edit: Please note the date of this post. Oil formulations change and any statements made here may not be true for current formulations of Mobil 1.
