Weed eater recommendations?
I think I might need a brush blade for the overgrowth part of my hill that is getting pretty dense, I could get a picture tommorow if needed but do brush blades work on most everything?
I have no trouble with mine on my Ryobi. I’ve cut down all kinds of weeds and even some small saplings. I have this one. I’m sure similar models would be good as well.
https://www.homedepot.com/p/RYOBI-Expand-It-8-in-Brush-Cutter-Trimmer-Attachment-RYBRC77/100313611
just my $0.02
I have a 21.1cc Hitachi-Koki CG 22EAS(SLP) that’s really solid. I do plan to get a Milwaukee M18 one soon though so I can finally ditch my last 2-cycle engine (good riddance).
I maintain a couple miles of MTB trails and putting some extra batteries in a backpack is far more convenient than juggling the weed eater AND a can of gasoline for a mile+.
Another vote for the Echo. I bought one 10 years ago when I noticed the landscapers all had Stihl chainsaws and Echo string trimmers. No problems so far. It swings .095 line mostly but I switch to .105 line for the tuff stuff.
Thinking about this
Echo SRM2400 lasted me for nearly 20 years. I believe it was 2 years ago I replaced it with Echo SRM 2620 and very happy with it. I'm using it on a 3 acre property on standard grass trimming and for some heavy thick weeds that get to 3ft high and are thick. Plenty of power.
If you only want trimmer and no attachment capable, Stihl FS70 is cheaper than Husky larger engine and same power. FS91 larger still engine and more power for 20 more dollars than the Husky.
Still - I would (did actually) go ahead and invest in a Kombi motor. I would actually step up one model from the one i had if i did it over again because I don't really care for the easy start, but one you use good stuff you'll be over big box store cheapies...
I have gas powered everything but had bad luck with trimmer reliability. I have a dozen chainsaws, ice auger, leaf blower, etc... they all fire right up. The trimmer - nope. Done with them.
I have many Dewalt tools and ended up getting a DCST920 and didn't look back. It's powerful, lasts a long time and has been completely reliable.
I keep that same hitachi as a backup. I really love everything about it except for the shape of the power head which is very easy to tip over. I’ve never had it stay upright in the back of my truck. Still a great, lightweight trimmer overall.
The husky 128ld you posted first is a decent machine and can run cheap attachments from many other brands but I don’t recommend it for trimming. The shaft is too short and it’ll give you a sore back if you’re over 5’8” or so. Doesn’t have a whole lot of power to run a blade either. The 525 series are absolute gems IMO and the best trimmers on the market right now.
If your looking at a 20v trimmer you are not going to get through very much thick stuff and if your looking at a 40v+ a spare battery alone will make the 4 stroke look like a bargin.
Not saying the battery is not the best option depending on how much and how thick your trimming.
I'm not sold on anything yet either way 100%, but the ones I have been looking at are 60v like the Ego carbon fiber power + 56v, or Dewalt Flexvolt 60
